| » maytag inner basket |
Model Number: mav6000aww Brand: Maytag Age: 5 - 10 years
I know where the leak is coming from, just above the tub support, which is #13 on the transmission parts explosion. Most likely it is seals #6 and 11, which are inexpensive parts. My real problem is how to get at those parts. I have removed he agitator,the upper basket rim, and the four bolts that hold the inner basket in place, but the basket doesn't just lift out. It seems that the basket is locked in place by corrosion, residue, etc. how can I pry this thing up? There is a hard seal around the agitator shaft, will that come up with the basket, or is the basket on top of this seal and nut?
Hi.
Rock gently the basket side to side to remove it. Most likely you will need to replace the tub seal assembly Part number: 12001598 Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
The inner basket is held by the 4screws witch you already removed. It has to come out. But then to remove the seal you need the spanner wrench and the seal nut tool.
Simon.
__________________
You posted:
"I have removed he agitator,the upper basket rim, and the four bolts that hold the inner basket in place, but the basket doesn't just lift out". Sorry I meant 4 bolts. Simon.
__________________
| Display Modes | |
| Remove outer tub from basket on Maytag 3000 | sehanks | Washer Repair | 2 | 02-10-2011 01:44 PM |
| inner basket nut | fixitnyc | Washer Repair | 1 | 08-03-2010 09:18 AM |
| Maytag Dishwasher (mdb7600awb) lower basket new tines install | dt132368 | Dishwasher Repair | 0 | 12-30-2009 01:25 PM |
| Maytag Washer links at Inlet Valve Basket | lgreenlea | Washer Repair | 0 | 08-17-2009 04:31 PM |
| Can't get basket off | willphule | Washer Repair | 5 | 02-25-2009 01:47 PM |
