Discuss
Fridigaire Front Loader leaking from dispenser door
 in
Washer Repair
Hello I have a Fridigaire Front Loader FWTR445RFS0 '97. The machine has been good over the years with little or
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Fridigaire Front Loader leaking from dispenser door
  #1 (permalink)
Old 06-14-2012, 10:40 AM
Junior Member
pboulo is on a distinguished road
Default Fridigaire Front Loader leaking from dispenser door
Model Number: FWTR445RF0   Brand: Frigidaire   Age: More than 10 years
Hello
I have a Fridigaire Front Loader FWTR445RFS0 '97. The machine has been good over the years with little or no problems other than a broken spring. We have always used liquid detergent in the machine, so no powder detergents.
Whats happening is when I turn on the machine to the wash cycle water begins to flow to the tub as expected but after 45-50 seconds the flow appears to back up in the dispenser and begin leaking from the from of the machine.
Steps taken so far:
1) I have removed the dispenser and cleaned it thoroughly
2) Tested the flow of water through the dispenser by using a quart pitcher and poring water through front of the dispenser.
3) Inspected the door boot and fill duct to the tub appears clear
4) Removed top of washer and inspected the overfill hose on top and it was clear as well.
The thing I cant seem to get to is the Duct-fill part # 131272300 to inspect closely.
So that may be where things are backing up...The only way it seems to get to that part is too remove the front panel.
Would removing the front panel be my next step?
How do you remove the front panel? does not look like an easy task...
or could it be something else...
Best Regards
Phil
Ads By Google
Related Models
Frigidaire FWTR445RFS0 Frg(v0) / Washer
Frigidaire FWTR445RFS1 Frg/washer
Frigidaire FWTR445RFS2 Frg(v0) / Front Load Washer
Frigidaire FWTR549GG Frg(v0) / Free Standing Washer
Frigidaire FWTR549GGS0 Frg/washer
Frigidaire FWTR549GS0
Frigidaire FWTR645RHS0 Frtld Wshr - Frigidaire
Frigidaire FWTR645RHS1 Frg(v0) / Front Load Washer
Frigidaire FWTR647GHS0 Frg(v0) / Washer
Frigidaire FWTR647GHS1 Frtld Wshr - Frigidaire
Frigidaire FWTR865RHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR865RHS0 Frg(v2) / Front Load Washer
Frigidaire FWTR867GHQ0 Frg(v1) / Front Load Washer
Frigidaire FWTR867GHS0 Frg(v2) / Front Load Washer
Frigidaire FWX133RBS0 Frg(v2) / 27 " Washer
Frigidaire FWX133RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX133RBS2 Frg(v1) / Washer
Frigidaire FWX133RBS3 Frg(v1) / Washer
Frigidaire FWX221AS0 Washer - Frigidaire
Frigidaire FWX221AS1 Washer - Frigidaire
Frigidaire FWX221AS2 Frigidaire/washer
Frigidaire FWX223LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX223LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX223LBS2 Frg(v2) / Washer
Frigidaire FWX223LBS3 Frg(v2) / Washer
Frigidaire FWX223LBS4 Frg(v0) / Washer
Frigidaire FWX223LBS5 Frg(v0) / Washer
Frigidaire FWX223LBS6 Frg/washer
Frigidaire FWX223LBS7 Frg(v0) / Free Standing Washer
Frigidaire FWX223LBS8 Frg/washer
Frigidaire FWX225RHS0 Frg(v0) / Washer
Frigidaire FWX225RHS1 Frg/washer
Frigidaire FWX233MRES0 Frg(v0) / Refrigerator
Frigidaire FWX233NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX233NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX233NBS2 Frg(v1) / Washer
Frigidaire FWX233NBS3 Frg(v0) / Washer
Frigidaire FWX233RES0 Frg(v0) / Washer
Frigidaire FWX233RES1 Frg(v0) / Washer
Frigidaire FWX233RES2 Frg(v0) / Washer
Frigidaire FWX233RES3 Frg(v0) / Washer
Frigidaire FWX233RES4 Frg(v0) / Washer
Frigidaire FWX233RES5 Frg(v0) / Washer
Frigidaire FWX233RES6 Frg/washer
Frigidaire FWX233RES7 Washer - Frigidaire
Frigidaire FWX233RET0 Frg(v0) / Free Standing Washer
Frigidaire FWX233RET1 Frg/washer
Frigidaire FWX414RGS0 Frg(v0) / Free Standing Washer
Frigidaire FWX414RGS1 Washer - Frigidaire
Frigidaire FWX433RBS0 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS1 Frg(v1) / 27 " Washer
Frigidaire FWX433RBS2 Frg(v3) / Washer
Frigidaire FWX433RBS3 Frg(v1) / Washer
Frigidaire FWX433RBS4 Frg(v1) / Washer
Frigidaire FWX433RBS5 Frg(v1) / Washer
Frigidaire FWX433RBT0 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT1 Frg(v2) / 27 " Washer
Frigidaire FWX433RBT2 Frg(v4) / Washer
Frigidaire FWX433RBT4 Frg(v2) / Washer
Frigidaire FWX433RBT5 Frg(v2) / Washer
Frigidaire FWX435RHS0 Frg(v0) / Washer
Frigidaire FWX435RHS1 Washer - Frigidaire
Frigidaire FWX435RHT0 Frg(v0) / Washer
Frigidaire FWX435RHT1 Washer - Frigidaire
Frigidaire FWX445LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS1 Frg(v1) / 27 " Washer
Frigidaire FWX445LBS2 Frg(v1) / Washer
Frigidaire FWX445LBS3 Frg(v2) / Washer
Frigidaire FWX445LBS4 Frg(v0) / Washer
Frigidaire FWX445NBS0 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS1 Frg(v2) / 27 " Washer
Frigidaire FWX445NBS2 Frg(v3) / Washer
Frigidaire FWX445NBS3 Frg(v2) / Washer
Frigidaire FWX445NBS4 Frg(v0) / Washer
Frigidaire FWX445RFS0 Frg(v1) / Washer
Frigidaire FWX445RFS1 Frg(v1) / Washer
Frigidaire FWX445RFS2 Frg(v1) / Washer
Frigidaire FWX445RFS3 Frg(v1) / Washer
Frigidaire FWX445RFS4 Frg(v1) / Free Standing Washer
Frigidaire FWX445RFS5 Washer - Frigidaire
Frigidaire FWX445RFT0 Frg(v2) / Washer
Frigidaire FWX445RFT1 Frg(v2) / Washer
Frigidaire FWX445RFT2 Frg(v2) / Washer
Frigidaire FWX445RFT3 Frg(v2) / Washer
Frigidaire FWX445RFT4 Frg(v2) / Free Standing Washer
Frigidaire FWX645DBD0 Frg(v2) / 27 " Washer
Frigidaire FWX645DBD1 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW0 Frg(v1) / 27 " Washer
Frigidaire FWX645DBW1 Frg(v2) / 27 " Washer
Frigidaire FWX645GES0 Frg(v0) / Washer
Frigidaire FWX645GES1 Frg(v0) / Washer
Frigidaire FWX645LBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645LBS1 Frg(v0) / 27 " Washer
Frigidaire FWX645LBS2 Frg(v4) / Washer
Frigidaire FWX645LBS3 Frg(v3) / Washer
Frigidaire FWX645LBS4 Frg(v1) / Washer
Frigidaire FWX645LBT2 Frg(v5) / Washer
Frigidaire FWX645LBT4 Frg(v2) / Washer
Frigidaire FWX645NBS0 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS1 Frg(v1) / 27 " Washer
Frigidaire FWX645NBS2 Frg(v2) / Washer
Frigidaire FWX645NBS3 Frg(v0) / Washer
Frigidaire FWX645NBT0 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT1 Frg(v2) / 27 " Washer
Frigidaire FWX645NBT2 Frg(v3) / Washer
Frigidaire FWX645RFS0 Frg(v0) / Washer
Frigidaire FWX645RFS1 Frg(v0) / Washer
Frigidaire FWX6968HW0 Frg(v0) / Washer
Frigidaire FWX6970EW0 Frg(v0) / Washer
Frigidaire FWX6970EW1 Frg(v0) / Washer
Frigidaire FWX6970EW2 Frg(v0) / Washer
Frigidaire FWX6970EW3 Frg(v0) / Washer
Frigidaire FWX6970EW4 Frg/washer
Frigidaire FWX6970EW5 Frg(v0) / Washer
Frigidaire FWX6971EW0 Frg(v0) / Washer
Frigidaire FWX6971EW1 Frg(v0) / Washer
Frigidaire FWX6971EW2 Frg(v0) / Washer
Frigidaire FWX6975EW0 Frg(v0) / Washer
Frigidaire FWX6975EW1 Frg(v0) / Washer
Frigidaire FWX6975EW2 Frg(v0) / Washer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My Neptune front loader is leaking water from the door durning the rinse cycle and I' rottengobstoppers Washer Repair 0 11-06-2011 06:46 AM
leaking front loader jeffy54 Washer Repair 3 03-05-2010 04:13 PM
Leaking front loader door Philbretz Washer Repair 1 12-29-2009 12:36 PM
leaking front loader jessiehannan Washer Repair 0 04-01-2009 04:05 PM
leaking front loader door /drum seal bfd Washer Repair 0 12-22-2008 07:21 PM
