Discuss
Is it easy to replace control board?
 in
Washer Repair
I had a tech come and check my washer because it would not agitate or spin. It was diagnosed as
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Is it easy to replace control board?
  #1 (permalink)
Old 01-24-2008, 07:33 PM
vwjohn vwjohn is offline
Junior Member
vwjohn is on a distinguished road
Default Is it easy to replace control board?
Model Number: WWSE5240G0WW   Brand: GE   Age: 1 - 5 years
I had a tech come and check my washer because it would not agitate or spin. It was diagnosed as the control board. Well being just a couple of months out warranty, I decided to give GE a call. They are sending out the board free of charge which I'm very happy about. Now the question. can I change this out myself? Is it just a matter of removing the old and plugging the new one in? The service tech want $79 to install, this on top of the $69 service call fee I already paid.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-25-2008, 04:07 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Quote:
Originally Posted by vwjohn View Post
...Now the question. can I change this out myself? Is it just a matter of removing the old and plugging the new one in?....
You were absolutely right.
This part is not too difficult to replace yourself.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 01-28-2008, 07:16 PM
Junior Member
Default
Gene-
I replaced the control board, but it still will not function. I checked the flashing LED on the motor board and it flashes 4 times. According to the code table it says to check the "Mode Shifter Coil". What is this? I cant find any reference to this on the internet.
Any help is apperciated. Thanks
  #4 (permalink)
Old 05-15-2008, 03:11 PM
Dee Smith Dee Smith is offline
Junior Member
Dee Smith is on a distinguished road
Default Ge Wwse5240g0ww
Hi, thank you for viewing. My GE super capacity started making really loud squeek during agitation I called guy out and he said it was the screw that goes to shaft and I would have to replace the nut on the pully. $10 part. but naturallyit is several hours for the call to take the machine apart. I went to GE and there was no part called nut pully. I really need to save$$ and fix myself....I have 5 grandbabies and it is just me. so any advice? thank you
  #5 (permalink)
Old 05-15-2008, 03:53 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Dee,
There is a part called "pulley nut" but I do not know how it could cause a loud squeak.
On other side it is normal to hear metal-to-metal "clunking" sounds at the beginning of the agitation cycle while the motor is in the "Mode Shifter Agitate Program" (about 20 seconds). If the washer is paused while in agitation, it is normal to hear sounds for an additional 30 seconds.
- The part number for the pulley nut is AP2045294 (just in case).
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryness control board moose2929 Dryer Repair 0 01-05-2008 01:55 PM
How to replace relay board? Marc Lombardini Oven Repair (including Ranges and Cooktops) 3 11-28-2007 09:15 AM
Can I replace the motor control board? Homerepairbob Washer Repair 1 11-24-2007 07:10 PM
Control board? rod Dishwasher Repair 1 11-05-2007 07:30 PM
GE Profile Control Board ??? markham Oven Repair (including Ranges and Cooktops) 4 08-21-2007 05:15 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
