Discuss
Washer error code 71
 in
Washer Repair
Frigidaire Affinity washer stopped working properly. Had this problem before -error code 68. Checked wiring and found box behind front
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer error code 71
  #1 (permalink)
Old 06-10-2012, 06:40 AM
Junior Member
ericdiy is on a distinguished road
Default Washer error code 71
Model Number: ATF7000FS0   Brand: Frigidaire   Age: 5 - 10 years
Frigidaire Affinity washer stopped working properly. Had this problem before -error code 68. Checked wiring and found box behind front panel was loose. Seems this is a common problem with these washers. Reattached the box and error code went away. Washer functioned well for about 1 year. Problem started again so I removed top to check that box had not come loose again. Appeared OK but still had error code. I put through washer through diagnostic test cycle. All functions seemed to work but error code 71 showed up at the end. Not sure what to do next.
I did attempt to run cycle afar diagnostic test in normal setting. Water entered but did not stop so I interrupted cycle and ran in spin only cycle to empty water out.
Also, I have matching dryer and it has started malfunctioning. Jumps back and forth between drying options. Mostly goes to delicates cycle. Ran diagnostic cycle on it and get an E4A error code. Sorry for combining posts.
Thanks for any help.
Related Models
Frigidaire ATF7000FS0 Frigidaire/washer
Frigidaire ATF7000FS1 WASHER
Frigidaire ATF8000FE0 WASHER
Frigidaire ATF8000FE1 WASHER
Frigidaire ATF8000FE2 WASHER
Frigidaire ATF8000FG0 WASHER
Frigidaire ATF8000FG1 WASHER
Frigidaire ATF8000FS0 WASHER
Frigidaire ATF8000FS1 WASHER
Frigidaire ATF8000FS2 WASHER
Frigidaire ATFB6000ES0 Frigidaire/washer
Frigidaire ATFB6000ES1 Frigidaire/washer
Frigidaire ATFB6000FS0 Frigidaire/washer
Frigidaire ATFB6700FS0 WASHER
Frigidaire ATFB7000EG0 Frigidaire/washer
Frigidaire ATFB7000EP0 Frigidaire/washer
Frigidaire ATFB7000ES0 Frigidaire/washer
Frigidaire ATFB7000ES1 Frigidaire/washer
Frigidaire ATG130NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG130NCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG130NCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG130NCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG130NLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG130NLD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG130NLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG130NLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG150NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG150NCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG150NCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG150NCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG150NCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG150NCW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG150NLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG150NLD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG150NLD2 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG150NLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG150NLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG150NLW2 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170NCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170NCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170NCW0 Wwh(v5) / Top Mount Refrigerator
Frigidaire ATG170NCW1 Wwh(v7) / Top Mount Refrigerator
Frigidaire ATG170NCW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170NLD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170NLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170NLD2 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170NLW0 Wwh(v6) / Top Mount Refrigerator
Frigidaire ATG170NLW1 Wwh(v8) / Top Mount Refrigerator
Frigidaire ATG170NLW2 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170VNCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170VNCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170VNCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170VNCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170VNLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170VNLD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170VNLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170VNLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG173NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG173NCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG173NCW0 Wwh(v5) / Top Mount Refrigerator
Frigidaire ATG173NCW1 Wwh(v7) / Top Mount Refrigerator
Frigidaire ATG173NLD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG173NLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG173NLW0 Wwh(v6) / Top Mount Refrigerator
Frigidaire ATG173NLW1 Wwh(v8) / Top Mount Refrigerator
Frigidaire ATG175NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG175NCD1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG175NCW0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG175NCW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG175NLD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire ATG175NLW0 Wwh(v6) / Top Mount Refrigerator
Frigidaire ATG180VNCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG180VNCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG180VNLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG180VNLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG185NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG185NCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG185NCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG185NCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG185NLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG185NLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATL/ATN130BK1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL/ATN130HK1 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL/ATN130WK1 Frg(v3) / Top Mount Refrigerator
General Electric ATL04LAA1 Room air conditioner
General Electric ATL05LAB1 Room air conditioner
Frigidaire ATL130BK1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL130BL0 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL130HK1 Frg(v3) / Top Mount Refrigerator
Frigidaire ATL130WK1 Frg(v5) / Top Mount Refrigerator
Frigidaire ATL130WKW1 Wwh(v11) / Top Mount Refrigerator
Frigidaire ATL130WL0 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL150BK2 Frg(v3) / Top Mount Refrigerator
Frigidaire ATL150HK2 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL150WK2 Tap(v7) / Top Mount Refrigerator
Frigidaire ATL150WKD2 Gib(v15) / Top Mount Refrigerator
Frigidaire ATL152BK0 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL152BK1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL152HK0 Frg(v0) / Top Mount Refrigerator
Frigidaire ATL152WK0 Gib(v12) / Top Mount Refrigerator
Frigidaire ATL152WK1 Frg(v2) / Top Mount Refrigerator
General Electric ATM04LAA1 Room air conditioner
General Electric ATM04LAA2 Room air conditioner
General Electric ATM04LBA1 Room air conditioner
General Electric ATM05LAB1 Room air conditioner
General Electric ATM05LAB2 Room air conditioner
General Electric ATM06LAC1 Room air conditioner
General Electric ATM06LAC2 Room air conditioner
General Electric ATM06LBC1 Room air conditioner
Frigidaire ATN130BK1 Frg(v2) / Top Mount Refrigerator
Frigidaire ATN130BK1-23 Tap(v20) / Top Mount Refrigerator
Frigidaire ATN130BK2 Frg(v1) / Top Mount Refrigerator
Frigidaire ATN130BL0 Frg(v3) / Top Mount Refrigerator
Frigidaire ATN130HK1 Frg(v4) / Top Mount Refrigerator
Frigidaire ATN130HK2 Frg(v2) / Top Mount Refrigerator
Frigidaire ATN130HKJ1 Kel(v28) / Top Mount Refrigerator
Frigidaire ATN130WK1 Frg(v6) / Top Mount Refrigerator
Frigidaire ATN130WK1-00 Tap(v24) / Top Mount Refrigerator
Frigidaire ATN130WK2 Frg(v3) / Top Mount Refrigerator
  #2 (permalink)
Old 06-11-2012, 10:35 AM
Banned
Chris_Polk is on a distinguished road
Default Code
E71 indicates "Wash NTC failure- (tub heater)" - you will need to swap hot and cold hoses, and then retry the unit.
  #3 (permalink)
Old 06-12-2012, 03:47 PM
Junior Member
Default
I checked the heating element and it reads 14+ ohms. The hoses are attached correctly. Should I still switch them?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG washer IE error code Fred123456 Washer Repair 1 03-21-2012 02:47 PM
LG Washer Error Code tE ccq Washer Repair 1 03-19-2012 07:51 PM
Washer error code F 51 anmika Washer Repair 1 11-02-2011 07:18 PM
LE error code on lg washer jrogers297 Washer Repair 0 12-02-2010 04:05 AM
Error code E38 washer things4u2 Washer Repair 1 09-20-2010 05:23 AM
