Discuss
Kenmore Elite Washer Won't Spin or Drain
 in
Washer Repair
Correction - I just unplugged the machine for a few minutes, and then ran the drain/spin cycle again to try
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Elite Washer Won't Spin or Drain
  #11 (permalink)
Old 06-16-2012, 07:14 PM
Junior Member
peetey is on a distinguished road
Default
Correction - I just unplugged the machine for a few minutes, and then ran the drain/spin cycle again to try to remove the remaining water in from below the bottom of the tub from when the rinse/spin cycle stopped before, and it is successfully running as I type this, in case this alters your diagnosis in any way.
  #12 (permalink)
Old 06-16-2012, 07:21 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Based on all this I think it is your transmission, that it is jamming in agitation and that is what is causing your problem.
As far as repair is concerned, you can purchase this same machine, a basic Whirlpool top loader for about $300 to $350.00 in our area, sometimes even less if it is on sale. The same model is sold under the Roper and Estate brands, and sometimes under the Admiral brand usually at an even lower price.
If you want to continue to play with it, see if there is a used appliance store in your area and they might have a used transmission they have sitting around that you can purchase inexpensively. The transmission comes out easily, three big screws undone and there you are.
__________________
  #13 (permalink)
Old 06-16-2012, 07:39 PM
Junior Member
Default
Thanks. So I guess you're advising a new machine. For what it's worth, I just ran the neutral drain/spin diagnostic test, and the second step, "motor drains ar medium speed" resulted in the humming and no response while it ran fine at both high and low speed. Is it still the transmission?
  #14 (permalink)
Old 06-20-2012, 07:57 PM
Junior Member
Default
Tech from APP suggested that it sounds like the electronic control board, so I ordered one and waiting for it to arrive. Does this sound reasonable, based on the newly discovered fact that the motor seems to run fine during the fast and slow "t4" test, but only hums at medium speed during the test?
  #15 (permalink)
Old 06-21-2012, 01:26 PM
Senior Expert
APP Volunteer
Default
Interesting, worth a try. You can return the part if it does not fix things.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Oasis Top Loader will not drain or spin Rolo1 Washer Repair 20 09-03-2013 01:04 PM
Kenmore Elite-water wont shut off, now wont drain or spin dbigotis Washer Repair 1 05-12-2009 05:27 PM
Kenmore Elite washer spin cycle noise Bikerdav Washer Repair 4 04-27-2009 08:56 PM
Kenmore elite would not Drain or spin makes loud noise doo Washer Repair 0 11-23-2008 01:58 PM
Kenmore elite spin drain problem srbakall Washer Repair 3 03-09-2008 06:45 PM
