Discuss
water does not drain all out on the spin cycle
 in
Washer Repair
the G.E. washer is only 2 years old, when it goes to the spin cycle the water doesn't drain all
Appliance Repair Forum > Appliance Repair Help > Washer Repair » water does not drain all out on the spin cycle
  #1 (permalink)
Old 09-12-2009, 07:06 AM
Junior Member
lavete is on a distinguished road
Default water does not drain all out on the spin cycle
Model Number: 31165524   Brand: GE   Age: 1 - 5 years
the G.E. washer is only 2 years old, when it goes to the spin cycle the water doesn't drain all out, some goes out but not all. thanks
Ads By Google
Related Models
Magic Chef 3116PRA Range - F/s Std Gas
Magic Chef 3116PRW Range - F/s Std Gas
Magic Chef 31203KAA Range - F/s Std Gas
Magic Chef 31203KAW Range - F/s Std Gas
Magic Chef 31203PAA Range - F/s Std Gas
Magic Chef 31203PAQ Range - F/s Std Gas
Magic Chef 31203PAV Range - F/s Std Gas
Magic Chef 31203SAA Range - F/s Std Gas
Magic Chef 31203SAW Range - F/s Std Gas
Magic Chef 31203WAA Range - F/s Std Gas
Magic Chef 31203WAW Range - F/s Std Gas
Magic Chef 3120SPA Range - F/s Std Gas
Magic Chef 3120SPL
Magic Chef 3120SPN
Magic Chef 3120SPW Range - F/s Std Gas
Magic Chef 3120SRA Range - F/s Std Gas
Magic Chef 3120SRW Range - F/s Std Gas
Magic Chef 31211SAA Range - F/s Std Gas
Magic Chef 31211SAW Range - F/s Std Gas
Magic Chef 31211WAA Range - F/s Std Gas
Magic Chef 31211WAM Range - F/s Std Gas
Magic Chef 31211WAV Range - F/s Std Gas
Magic Chef 31211WAW Range - F/s Std Gas
Magic Chef 31211XAA Range - F/s Std Gas
Magic Chef 31211XAS Range - F/s Std Gas
Magic Chef 31211XAT
Magic Chef 31211XAW Range - F/s Std Gas
Magic Chef 31213SAA Range - F/s Std Gas
Magic Chef 31213SAW Range - F/s Std Gas
Magic Chef 31213WAA Range - F/s Std Gas
Magic Chef 31213WAM Range - F/s Std Gas
Magic Chef 31213WAQ
Magic Chef 31213WAV Range - F/s Std Gas
Magic Chef 31213WAW Range - F/s Std Gas
Magic Chef 31213XAA Range - F/s Std Gas
Magic Chef 31213XAT
Magic Chef 31213XAW Range - F/s Std Gas
Magic Chef 3121SPA Range - F/s Std Gas
Magic Chef 3121SPL
Magic Chef 3121SPW Range - F/s Std Gas
Magic Chef 3121SRA Range - F/s Std Gas
Magic Chef 3121SRW Range - F/s Std Gas
Magic Chef 3121STA Range - F/s Std Gas
Magic Chef 3121STW Range - F/s Std Gas
Magic Chef 3121WPA Range - F/s Std Gas
Magic Chef 3121WPL
Magic Chef 3121WPV Range - F/s Std Gas
Magic Chef 3121WPW Range - F/s Std Gas
Magic Chef 3121WRA Range - F/s Std Gas
Magic Chef 3121WRV Range - F/s Std Gas
Magic Chef 3121WRW Range - F/s Std Gas
Magic Chef 3121WTA Range - F/s Std Gas
Magic Chef 3121WTV Range - F/s Std Gas
Magic Chef 3121WTW Range - F/s Std Gas
Magic Chef 3121XPA Range - F/s Std Gas
Magic Chef 3121XPL Range - F/s Std Gas
Magic Chef 3121XPS Range - F/s Std Gas
Magic Chef 3121XPW Range - F/s Std Gas
Magic Chef 3121XRA Range - F/s Std Gas
Magic Chef 3121XRA-UX Range - F/s Std Gas
Magic Chef 3121XRA-X Range - F/s Std Gas
Magic Chef 3121XRS Range - F/s Std Gas
Magic Chef 3121XRW Range - F/s Std Gas
Magic Chef 3121XRW-UX Range - F/s Std Gas
Magic Chef 3121XRW-X Range - F/s Std Gas
Magic Chef 3121XTA Range - F/s Std Gas
Magic Chef 3121XTS Range - F/s Std Gas
Magic Chef 3121XTW Range - F/s Std Gas
Magic Chef 3126SRA Range - F/s Std Gas
Magic Chef 3126SRW Range - F/s Std Gas
Magic Chef 3126STA Range - F/s Std Gas
Magic Chef 3126STW Range - F/s Std Gas
Magic Chef 3127STA Range - F/s Std Gas
Magic Chef 3127STW Range - F/s Std Gas
Magic Chef 3127WTA Range - F/s Std Gas
Magic Chef 3127WTV Range - F/s Std Gas
Magic Chef 3127WTW Range - F/s Std Gas
Magic Chef 3127XTA Range - F/s Std Gas
Magic Chef 3127XTW Range - F/s Std Gas
Magic Chef 31311SAA Range - F/s Std Gas
Magic Chef 31311SAW Range - F/s Std Gas
Magic Chef 31311WAA Range - F/s Std Gas
Magic Chef 31311WAW Range - F/s Std Gas
Magic Chef 31315VAM Range - F/s Std Gas
Magic Chef 31315VAV Range - F/s Std Gas
Magic Chef 31315VBM Range - F/s Std Gas
Magic Chef 31315VBV Range - F/s Std Gas
Magic Chef 31315WAM Range - F/s Std Gas
Magic Chef 31315WAV Range - F/s Std Gas
Magic Chef 31315XAA Range - F/s Std Gas
Magic Chef 31315XAW Range - F/s Std Gas
Magic Chef 31315XBA Range - F/s Std Gas
Magic Chef 31315XBW Range - F/s Std Gas
Magic Chef 3141XRA Range - F/s Std Gas
Magic Chef 3141XRW Range - F/s Std Gas
Magic Chef 3141XTA Range - F/s Std Gas
Magic Chef 3141XTW Range - F/s Std Gas
Magic Chef 3147XRA Range - F/s Std Gas
Magic Chef 3147XRA-X Range - F/s Std Gas
Magic Chef 3147XRW Range - F/s Std Gas
Magic Chef 3147XRW-X Range - F/s Std Gas
Magic Chef 3147XTA Range - F/s Std Gas
Magic Chef 3147XTW Range - F/s Std Gas
Magic Chef 3167VTV Range - F/s Std Gas
Magic Chef 3167VTW Range - F/s Std Gas
Magic Chef 3167VUV Range - F/s Std Gas
Magic Chef 3167XRA Range - F/s Std Gas
Magic Chef 3167XRA-X Range - F/s Std Gas
Magic Chef 3167XRW Range - F/s Std Gas
Magic Chef 3167XRW-X Range - F/s Std Gas
Magic Chef 3167XTA Range - F/s Std Gas
Magic Chef 3167XTA-X Range - F/s Std Gas
Magic Chef 3167XTW Range - F/s Std Gas
Magic Chef 3167XTW-X Range - F/s Std Gas
Magic Chef 3167XUA Range - F/s Std Gas
Magic Chef 3167XUA-X Range - F/s Std Gas
Magic Chef 3167XUW Range - F/s Std Gas
Magic Chef 3167XUW-X Range - F/s Std Gas
Magic Chef 3167XYA Range - F/s Std Gas
Magic Chef 3167XYW Range - F/s Std Gas
  #2 (permalink)
Old 09-14-2009, 07:31 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Your model number is not complete, so that best answer I can give you is that there is something partially obstructing the pump or drain hoses. Check them out.
If you need more info, post the results of your inspection of the drain system and your complete model number.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
After wash cycle will not drain and spin out IndianaPanda Washer Repair 2 12-11-2009 02:01 AM
Drain cycle does not spin sbc1967 Washer Repair 2 02-27-2009 05:15 AM
washer will not drain for 1st spin cycle. Does finish with spin dry tec6422 Washer Repair 1 01-23-2009 07:44 AM
Washer will not drain during spin cycle tbell Washer Repair 3 11-16-2008 04:15 PM
Washer won't drain during spin cycle. Water Pump Belt discovered on floor sandydjdm Washer Repair 1 08-14-2007 07:41 PM
