water does not drain all out on the spin cycle
the G.E. washer is only 2 years old, when it goes to the spin cycle the water doesn't drain all out, some goes out but not all. thanks
Your model number is not complete, so that best answer I can give you is that there is something partially obstructing the pump or drain hoses. Check them out.
If you need more info, post the results of your inspection of the drain system and your complete model number. Thanks |
| All times are GMT -7. The time now is 08:30 PM. |
