| » Kenmore Series 90 Washer Auger not spinning |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: 110.20922990 Brand: Kenmore Age: 5 - 10 years
hi,
I have a Kenmore Series 90 washer 8yo. Model110.20922990 The problem is that the Auger on the agitator does not move all of the time. It is suppoosed to draw the clothes into the water. Sometimes it does and other times it seems to slip. I took apart down to the agiitator and everything seems to be fine. I did not see any broken or chipped parts. Is there a part below the agitator it that is suppossed to engage the Auger and may be causing the problem? thanks |
Most likely the problem caused by the worn out agitator cam dogs (#21 on the break down diagram).
In order to remove the auger, remove the agitator cap (#1 on the break down diagram) and unscrew the retainer (#22 on the break down diagram). You will need a 1/2" socket wrench driver to remove the retainer. - The part number for the agitator repair kit is AP3094544 Gene.
__________________
Professional appliance repair services in Orange County, California. Last edited by Gene : 02-08-2008 at 12:46 PM. |
gene's assessment was spot on and it took less than 5 minutes to fix. I ordered the part and it was here the next day even though i used economy.
Thank you Gene! Last edited by howiey@yahoo.com : 01-30-2008 at 07:35 PM. |
I'm glad you were able to fix it.
__________________
Professional appliance repair services in Orange County, California. |
I know my dogs need replaced but when I go to take it apart the pin that holds the retainer sping in is just that a pin.No way to unscrew it. I have a Kenmore 90 series model #110.28922790. I do not know if there is a trick to it suck as, pull up on one part to loosen another. Any help would be greatful Thanks
I did not get what part are you talking about. Can you refer to a references number on the break down diagram?
__________________
This is the retainer which should be unscrewed and you have to use a 1/2" socket wrench driver to do it.
__________________
| Display Modes | |
| Kenmore Washer Series 80. Won't spin, agitate and makes a grinding noise | Scottmcc | Washer Repair | 6 | 01-05-2008 07:24 AM |
| 800 series kenmore with no sensors? | hardhat | Dryer Repair | 0 | 12-14-2007 07:06 PM |
| kenmore washer 110.26852501 spinning intermittently | 88ply | Washer Repair | 1 | 12-08-2007 03:01 PM |
| Kenmore 90 Series Wahser | cid94 | Washer Repair | 3 | 11-14-2007 12:34 PM |
| Kenmore 80-series washer skips spin time | mac | Washer Repair | 1 | 08-14-2007 06:52 PM |
