I have a maytag MAV6000AWW and the washer doesnt spin any longer on the rinse cycle. The water pump seems to have some wear and I am trying to figure out if that is the issue. Any suggestions welcome.
Thanks in advance!
Tilt the washer back and remove the belt. Check how freely the pump pulley is moving in both directions. If it does not move freely, replace the pump. Also check all drain hoses. - The drain pump assembly Part number: 35-6465
Problem solved thank you so much :)
You are welcome. I'm glad it's up and running.
