[FONT='Verdana','sans-serif']The washing machine works fine with the exception of the following intermittent problem: - [/font] [FONT='Verdana','sans-serif'] - Washer doesn’t always start agitating in the wash cycle[/font] [FONT='Verdana','sans-serif'] - Washer doesn’t always start agitating in the rinse cycle[/font] [FONT='Verdana','sans-serif'] - Washer doesn’t always start agitating if I stop the machine in the middle of a cycle & turn it back on again. [/font] [FONT='Verdana','sans-serif'][/font] [FONT='Verdana','sans-serif']If it starts to agitate, it usually agitates for the whole cycle. It seems that the problem is only when it needs to start to agitate. [/font] [FONT='Verdana','sans-serif'][/font] [FONT='Verdana','sans-serif']Example: Sometimes it will perform the wash cycle fine but when it goes to the rinse cycle, it fills with water and then I hear a little switch but it just sits there and then eventually goes to the spin cycle (with no problem in the spin cycle) but the clothes are not really “rinsed”. [/font] [FONT='Verdana','sans-serif'][/font] [FONT='Verdana','sans-serif']It basically goes through all the cycles it’s supposed to go through, but the agitator doesn’t turn on (only sometimes it does).[/font]
Check all wires. their connections and plugs in the control panel and at the motor. Check the speed switch according to the wiring diagram. If there is nothing wrong then the problem most likely is a bad timer. - The timer Part number: AP4028325
