Discuss
whirlpool washer trouble
 in
Washer Repair
My washer started to leak water from the bottom front and was making a hig pitched sound. I replaced the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » whirlpool washer trouble
  #1 (permalink)
Old 06-01-2012, 08:09 AM
Junior Member
mtthompson is on a distinguished road
Default whirlpool washer trouble
Model Number: lsb6200kq0   Brand: Whirlpool   Age: More than 10 years
My washer started to leak water from the bottom front and was making a hig pitched sound. I replaced the pump and it stopped leaking during a cycle, but sound continued and I found water on the floor hours after I ran a load. I tried another load to help me isolate the sound and it got much worse during the spin cycle, then there was a loud clunk. I shut it off immediately and again hours later there was a little bit of water. Help!!
Related Models
Whirlpool LSB6200KQ0 WASHER
Whirlpool LSB6200KQ1 AUTOMATIC WASHER
Whirlpool LSB6200PQ0 AUTOMATIC WASHER
Whirlpool LSB6200PQ1 AUTOMATIC WASHER
Whirlpool LSB6200PQ2 AUTOMATIC WASHER
Whirlpool LSB6300LQ0 WASHER - DIRECT DRIVE
Whirlpool LSB6300LW0 WASHER - DIRECT DRIVE
Whirlpool LSB6300LW1 AUTOMATIC WASHER
Whirlpool LSB6300LW2 AUTOMATIC WASHER
Whirlpool LSB6300LW3 AUTOMATIC WASHER
Whirlpool LSB6300PW0 AUTOMATIC WASHER
Whirlpool LSB6300PW1 AUTOMATIC WASHER
Whirlpool LSB6300PW3 AUTOMATIC WASHER
Whirlpool LSB6300PW4 AUTOMATIC WASHER
Whirlpool LSB6400KQ0 WASHER
Whirlpool LSB6400KQ1 WASHER
Whirlpool LSB6400LW0 WASHER - DIRECT DRIVE
Whirlpool LSB6400LW1 AUTOMATIC WASHER
Whirlpool LSB6500PW0 AUTOMATIC WASHER
Whirlpool LSB6500PW1 AUTOMATIC WASHER
Whirlpool LSB6500PW2 AUTOMATIC WASHER
Whirlpool LSB6500PW3 AUTOMATIC WASHER
Whirlpool LSB6500PW4 AUTOMATIC WASHER
 LSC21943ST Refrigerator
 LSC26905SB Refrigerator
 LSC26905SW Refrigerator
 LSC26905TT Refrigerator
 LSC26945SW Refrigerator
 LSC26945TT Refrigerator
 LSC27910SB Refrigerator
 LSC27910ST Refrigerator
 LSC27910SW Refrigerator
 LSC27910TT Refrigerator
 LSC27926SB Refrigerator
 LSC27926ST Refrigerator
 LSC27926SW Refrigerator
 LSC27926TT Refrigerator
 LSC27931SB Refrigerator
 LSC27931ST Refrigerator
 LSC27931SW Refrigerator
 LSC27950SB Refrigerator
 LSC27950ST Refrigerator
 LSC27950SW Refrigerator
 LSC27970ST Refrigerator
 LSC27990TT Refrigerator
 LSC27991TT Refrigerator
Whirlpool LSC5000PQ0 AUTOMATIC WASHER
Whirlpool LSC5000PQ1 AUTOMATIC WASHER
Whirlpool LSC5000PQ2 AUTOMATIC WASHER
Whirlpool LSC6244AW0 Washers*
Whirlpool LSC6244BQ0 Washers*
Whirlpool LSC6244BW0 Washers*
Whirlpool LSC8244BG0 AUTOMATIC WASHER
Whirlpool LSC8244BG1 AUTOMATIC WASHER
Whirlpool LSC8244BN0 AUTOMATIC WASHER
Whirlpool LSC8244BN1 AUTOMATIC WASHER
Whirlpool LSC8244BQ0 AUTOMATIC WASHER
Whirlpool LSC8244BQ1 AUTOMATIC WASHER
Whirlpool LSC8244BW0 AUTOMATIC WASHER
Whirlpool LSC8244BW1 AUTOMATIC WASHER
Whirlpool LSC8244BZ0 AUTOMATIC WASHER
Whirlpool LSC8244BZ1 AUTOMATIC WASHER
Whirlpool LSC8244DQ0 AUTOMATIC WASHER
Whirlpool LSC8244DZ0 AUTOMATIC WASHER
Whirlpool LSC8244EQ0 WASHER
Whirlpool LSC8244EQ1 WASHER
Whirlpool LSC8244EZ0 WASHER
Whirlpool LSC8244EZ1 WASHER
Whirlpool LSC8245AN0 AUTOMATIC WASHER
Whirlpool LSC8245AQ0 AUTOMATIC WASHER
Whirlpool LSC8245AW0 Washers*
Whirlpool LSC8245BW0 Washers*
Whirlpool LSC9000PW0 AUTOMATIC WASHER
Whirlpool LSC9000PW1 AUTOMATIC WASHER
Whirlpool LSC9000PW2 AUTOMATIC WASHER
Whirlpool LSC9245BN0 AUTOMATIC WASHER
Whirlpool LSC9245BN1 AUTOMATIC WASHER
Whirlpool LSC9245BQ0 AUTOMATIC WASHER
Whirlpool LSC9245BQ1 AUTOMATIC WASHER
Whirlpool LSC9245BW0 AUTOMATIC WASHER
Whirlpool LSC9245BW1 AUTOMATIC WASHER
Whirlpool LSC9245BZ0 AUTOMATIC WASHER
Whirlpool LSC9245BZ1 AUTOMATIC WASHER
Whirlpool LSC9355AG0 AUTOMATIC WASHER
Whirlpool LSC9355AN0 AUTOMATIC WASHER
Whirlpool LSC9355AW0 Washers*
Whirlpool LSC9355BN0 AUTOMATIC WASHER
Whirlpool LSC9355BN1 AUTOMATIC WASHER
Whirlpool LSC9355BQ0 AUTOMATIC WASHER
Whirlpool LSC9355BQ1 AUTOMATIC WASHER
Whirlpool LSC9355BW0 AUTOMATIC WASHER
Whirlpool LSC9355BW1 AUTOMATIC WASHER
Whirlpool LSC9355BZ0 AUTOMATIC WASHER
Whirlpool LSC9355BZ1 AUTOMATIC WASHER
Whirlpool LSC9355DQ0 AUTOMATIC WASHER
Whirlpool LSC9355DZ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ0 AUTOMATIC WASHER
Whirlpool LSC9355EQ1 DIRECT-DRIVE WASHER
Whirlpool LSC9355EZ0 AUTOMATIC WASHER
Whirlpool LSC9355EZ1 DIRECT-DRIVE WASHER
Admiral LSD2615HEB REF - SXS/I&W
Admiral LSD2615HEW REF - SXS/I&W
Admiral LSD2615HEZ REF - SXS/I&W
Maytag LSE1000 STACKED LAUNDRY- ELE
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-8 STACKED LAUNDRY- ELE
Jenn-Air LSE2700W-C STACKED LAUNDRY- ELE
Jenn-Air LSE2704W STACKED LAUNDRY- ELE
Jenn-Air LSE2704W-8 STACKED LAUNDRY- ELE
Maytag LSE7800 STACKED LAUNDRY- ELE
Maytag LSE7800ACE STACKED LAUNDRY- ELE
Maytag LSE7800ACL STACKED LAUNDRY- ELE
Maytag LSE7800ACW STACKED LAUNDRY- ELE
Maytag LSE7800ADE STACKED LAUNDRY- ELE
Maytag LSE7800ADL STACKED LAUNDRY- ELE
Maytag LSE7800ADW STACKED LAUNDRY- ELE
Maytag LSE7800AEE STACKED LAUNDRY- ELE
Maytag LSE7800AEL STACKED LAUNDRY- ELE
Maytag LSE7800AEW STACKED LAUNDRY- ELE
  #2 (permalink)
Old 06-01-2012, 05:58 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
You should remove the cabinet, bypass the lid switch and run the washer to pin point the noise and the leak sours.Try to remove the pump first, then the motor.
Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Trouble with Whirlpool washer! gamebird Oven Repair (including Ranges and Cooktops) 0 08-21-2011 10:44 PM
Whirlpool Washer has trouble spinning thomasc Washer Repair 1 10-25-2010 09:40 AM
whirlpool duet trouble wildfire14032 Washer Repair 1 08-26-2009 12:26 PM
whirlpool washer has trouble spinning ploose@omnek.com Washer Repair 1 03-06-2009 08:11 PM
whirlpool double oven trouble xmasvalley Oven Repair (including Ranges and Cooktops) 1 01-25-2009 07:12 AM
