Discuss
Washer Thumping
 in
Washer Repair
The washer really thumping during the spin cycle. The tub was wobbling badly. It looks like one of the springs
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Thumping
  #1 (permalink)
Old 08-12-2007, 07:03 AM
mwct mwct is offline
Junior Member
mwct is on a distinguished road
Default Washer Thumping
Model Number: LSR7233DW0   Brand: Whirlpool   Age: 1 - 5 years
The washer really thumping during the spin cycle. The tub was wobbling badly. It looks like one of the springs came off (tub balance spring) - it is hanging on the back support (spring bracket). Where does the other end go?
Related Models
Whirlpool LSR7233DW0
Whirlpool LSR7233DZ0
Whirlpool LSR7233DZ1
Whirlpool LSR7233EQ0
Whirlpool LSR7233EQ1
Whirlpool LSR7233EW0
Whirlpool LSR7233EZ0
Whirlpool LSR7233EZ1
Whirlpool LSR7233HQ0
Whirlpool LSR7233HZ0
Whirlpool LSR7300PQ0 Automatic Washer
Whirlpool LSR7300PQ1 Automatic Washer
Whirlpool LSR7300PQ2 Automatic Washer
Whirlpool LSR7333PQ0 Automatic Washer
Whirlpool LSR7333PQ1 Automatic Washer
Whirlpool LSR7333PQ3 Automatic Washer
Whirlpool LSR7333PQ4 Automatic Washer
Whirlpool LSR8010PQ0 Automatic Washer
Whirlpool LSR8010PQ1 Automatic Washer
Whirlpool LSR8010PQ2 Automatic Washer
Whirlpool LSR8010PT0 Automatic Washer
Whirlpool LSR8010PT1 Automatic Washer
Whirlpool LSR8010PT2 Automatic Washer
Whirlpool LSR8133HQ0
Whirlpool LSR8133HZ0
Whirlpool LSR8200EQ0
Whirlpool LSR8200EZ0
Whirlpool LSR8233EQ0
Whirlpool LSR8233EQ1
Whirlpool LSR8233EZ0
Whirlpool LSR8233EZ1
Whirlpool LSR8233JQ0
Whirlpool LSR8233JQ1
Whirlpool LSR8233JT0
Whirlpool LSR8233JT1
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0
Whirlpool LSR8433KQ1 Automatic Washer
Whirlpool LSR8433KQ2 Automatic Washer
Whirlpool LSR8433KT0
Whirlpool LSR8433KT1 Automatic Washer
Whirlpool LSR8433KT2 Automatic Washer
Whirlpool LSR8444LQ0
Whirlpool LSR8444LQ1 Automatic Washer
Whirlpool LSR8444LT0
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 Automatic Washer
Whirlpool LSR9434PQ1 Automatic Washer
Whirlpool LSR9434PQ3 Automatic Washer
Whirlpool LSR9434PQ4 Automatic Washer
Whirlpool LSR9434PT0 Automatic Washer
Whirlpool LSR9434PT1 Automatic Washer
Whirlpool LSR9434PT3 Automatic Washer
Whirlpool LSR9434PT4 Automatic Washer
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0
Whirlpool LSS9244EZ0
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
Whirlpool LST8244BZ0
Whirlpool LST8244BZ1
Whirlpool LST8244DQ0
Whirlpool LST8244DZ0
  #2 (permalink)
Old 08-12-2007, 08:32 AM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Does it look like this spring?
Spring Photo 1
Spring Photo 2
or this one..
Spring Photo 3
Spring Photo 4
__________________
John Pahl
ApplianceJunk.com
ApplianceDigest.com
  #3 (permalink)
Old 08-12-2007, 11:48 AM
Junior Member
Default Thank You
Thank you.
It looks like 1, 2 and 4; just dangling photo 1. From photo 2 it looks like it needs to be attached to the frame. There is no clip, but a small hole. I easily extended the spring and attached it in the hole. Did I get it right?
R/
Mike
  #4 (permalink)
Old 08-12-2007, 12:20 PM
Senior Expert
APP Volunteer
Default
Yeah, that's right.
__________________
John Pahl
ApplianceJunk.com
ApplianceDigest.com
  #5 (permalink)
Old 08-12-2007, 01:20 PM
Junior Member
Default Thank You
Thank you again!
It seems to be working. It is amazing how that spring keeps everything in line. The play in the drum does not seem to be as stiff as it was before - perhaps it is my imagination. We were on vacation and our son was left to his own devices. He has no idea there was a problem and we have no idea how much it thrashed. Is there anything I should be looking for?
R/
Mike
  #6 (permalink)
Old 08-13-2007, 04:30 PM
JackieBrown JackieBrown is offline
Junior Member
JackieBrown is on a distinguished road
Default Check the outer tub
Mike, I would examine the outer plastic tub.
I have this model washer and in seven years I've had to put in three outer tubs because for some reason, with all the springs on right, the tub will go so out of balance that the balance ring on the inner tub interferes with and cuts gashes completely through the outer tub, fortunately(?) near the top edge, so very little water escapes. It seems to go out of balance at the end of the spin cycle. I'm putting it back together right now.
The Whirlpool serviceman told me inner tub and balance ring are o.k. (sloshing noises). He couldn't explain why the tubs keep getting cut. Gasket had no sealant. Is sealant recommended? Old gasket looks like new and drive block looks good and tabs are square and engage perfectly. The triangle looked a little off, but the brown sliders look good with very minor flat plateau wear patterns.
Anybody have any hints?
Thanks, James
P.S. Sorry to hijack the tread
P.P.S. Note the prior attempt to repair the tub with silver foil tape. That was a $150 "repair"(?) by a local appliance shop. I'd laugh if I hadn't paid for that...
  #7 (permalink)
Old 04-08-2008, 05:38 PM
ropnald@yahoo.com ropnald@yahoo.com is offline
Junior Member
ropnald@yahoo.com is on a distinguished road
Default Washer machine
It seems the drum is thumping when spinning
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
