washer was smoking the other day- let cool down and started working again - notice white powder under drum in bottom where transmission is fastened to center of metal bottom tray- thrust bear plastic grinding up? any ideas- ran short cycle the other day seemed OK- thanks in advance DKAY
That white powder is the disintegration of the snubber, this part here Part number: AP4024496
It will have to be replaced, because your washer will start to wobble and make a lot of noise in the spin cycle.
