Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   replace part (http://forum.appliancepartspros.com/washer-repair/47802-replace-part.html)
garciar 09-10-2009 05:41 PM
replace part
how do i remove the module that controls the cycle settings? i already removed the panel but need to remove the knob and dont want to break it.
Frank / APP Team 09-11-2009 06:27 AM
Quote:
The circular disc in the center of the knob pops off. You'll need a small screwdriver to pry it off. With that removed, you'll then see a retaining clip, you can use the same screwdriver to pop it off. After that everything will come apart for you. Look on page 4 in the below link and you can see the breakdown.
Model LAT9314AAE
garciar 09-11-2009 05:36 PM
replace part
hey thanks for the info got it going now. thanks again
