| » kelvinator top loader |
Model Number: MW058k Brand: -other- Age: 5 - 10 years
My Kelvinator Top Loader Fills But Does Not Agitate Or Spin.
Sounds Like Its Trying To Spin But Straining.lid Switch Seems Ok Ads By Google Related Models |
Can you re check your model number, the one you posted does not come up.
If this is a standard top loader, see if you can take off the front panel and inspect the belt. See if it is hung up in any manner, then take it off and see if the motor is turning in spin cycle. Then unplug the machine and see if you can turn the pulley. If you need more info, post the model number and the result of the above. Thanks
__________________
Quote:
Thanks for your reply .The model is GW058k earlier version of GW611.It does not have a belt but a direct drive brushless motor.I have found the fault and fixed it. I checked out all the circuitry with a meter everything seemed ok. I then rechecked the lid switch and got intermittent readings. I cleaned the switch with a contact cleaner and a sspray of CRC that got the switch prforing correctly but not the machine Looking further I found that the wireing connector to the pump were corroded.I gave them the same treatment now the machine is running like new. This model is popular in NZ. KIA ORA JONNYDUBH. |
| Display Modes | |
| Kelvinator top loader washer drops black spots on the floor in circular pattern | Tony Chad | Washer Repair | 1 | 11-19-2009 03:46 PM |
| Need Help with Kelvinator Washer | jemunger | Washer Repair | 2 | 05-19-2009 03:41 PM |
| Kelvinator parts | freddy01@charter.net | Oven Repair (including Ranges and Cooktops) | 0 | 05-17-2009 10:47 AM |
| Kelvinator Refrigerator/Freezer | ChuckHerzog | Refrigerator & Freezer Repair | 1 | 01-15-2009 08:57 PM |
| Kelvinator Timer? | deebee | Refrigerator & Freezer Repair | 0 | 03-31-2008 11:25 AM |
