Neptune model MAH3000AWW starts, runs for less than a minute
Unfortunately you have one of the most unreliable, error prone machines ever made.
If you have not had the wax motors and control board replaced, they control board is possibly your problem, and if you decide to replace it you will need to replace the wax motor that operate the door lock and dispenser also.
The better solution is to replace the washer, since you may spend a lot of money and either not solve the problem or have a machine that is still prone to failure even if it works this time.
