Please help.... Washer has been constantly beeping for 3 days now. I have unplugged for time intervals from 1 minute to 1 day. I found the service sheet in the back and accessed the codes. I am getting an E4 and E7 error message flashing. At times the beeping slows or even stops for a few minutes and then starts up again. I can get it to load some water and drain it when I hit the right buttons but some of the buttons revert back to "default" values. for example if I choose cold, it may switch itself to hot or something other than what I picked. I think its the control board but hate to spend $150 on a guess.
These two error codes leading to the two different problems: slow drain and push-buttons. Remove the front panel and check the drain pump and hoses from the tub to the pump and from the pump out. Post the results. Replace the control board and the overlay. - The control board Part number: WH42X10486
