unit1018
#1 Posted : Sunday, May 20, 2012 1:33:21 PM(UTC)
unit1018
started flashing err loc on display so i changed the door lock assembly and its still doing it troubleshoot sheet says it could be the control board but which one is it, the main control board with the display on it or the motor control im confused as to which one it is and where is this other board.......please help!!! Eric....
sidfink43
#2 Posted : Wednesday, May 23, 2012 5:23:14 PM(UTC)
sidfink43
It is probably the main control board. The motor control board does what it says, it controls the motor.
Try changing out the main board and see if that fixes things. If you buy from this site and the part does not fix the problem you can return it.
Use your model number to see an exploded view of your machine in the 'Find Parts' section.
Frigidaire Door Lock ? I think (Washer Repair)
by schatz78240 1/14/2013 6:33:57 AM(UTC)
Frigidaire Door Lock and F9 error code (Oven Repair (including Ranges and Cooktops))
by chispaluz 7/10/2010 10:58:52 AM(UTC)
Frigidaire door lock assembly (Washer Repair)
by frustratedmomma 10/21/2009 7:34:27 PM(UTC)
frigidaire door lock repair (Washer Repair)
by docjlee 6/17/2009 9:49:15 PM(UTC)
Frigidaire Door Lock asemble repair (Washer Repair)
by heyingh 12/16/2007 8:06:02 PM(UTC)
