Discuss
Kenmore Elite Oasis HE Washer
 in
Washer Repair
Washer is about 2 1/2 yrs.. old. Started giving an F1 code the last couple of weeks. When I hit
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Elite Oasis HE Washer
  #1 (permalink)
Old 09-09-2009, 06:07 AM
Junior Member
bap2523 is on a distinguished road
Default Kenmore Elite Oasis HE Washer
Model Number: 110-27062603   Brand: Kenmore   Age: 1 - 5 years
Washer is about 2 1/2 yrs.. old. Started giving an F1 code the last couple of weeks. When I hit start it would start to load and then the F1 code would come up and the washer would start to beep. Per the manual I cleared it and then hit start again and it was ok. Well now it will not run at all, I can't clear the F1 code. Anyone know what could be causing this? I have a call into a repair man but I have a feeling it will cost me a fortune just to have him come out to look at it.
Ads By Google
Related Models
Kenmore 110.0  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.088732791  WASHER/DRYER LAUNDRY SYSTEM
Kenmore 110.1  SEARS ELECTRIC EASE-O-MATIC SPRING
Kenmore 110.10202000  COMPACT WASHER
Kenmore 110.10202001  WASHER
Kenmore 110.10502990  AUTOMATIC WASHER
Kenmore 110.10502991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.10852990  AUTOMATIC WASHER
Kenmore 110.10852991  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12202100  WASHER
Kenmore 110.12502100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.12852100  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.13202200  WASHER
Kenmore 110.13212200  AUTOMATIC WASHER
Kenmore 110.14212200  AUTOMATIC WASHER
Kenmore 110.16101690  AUTOMATIC WASHER
Kenmore 110.16101691  AUTOMATIC WASHER
Kenmore 110.16202690  WASHER
Sears 110.16202691  AUTOMATIC WASHER
Kenmore 110.16502690  WASHER
Sears 110.16502691  AUTOMATIC WASHER
Sears 110.16502692  AUTOMATIC WASHER
Kenmore 110.16512690  WASHER
Kenmore 110.18202790  AUTOMATIC WASHER
Kenmore 110.18522790  AUTOMATIC WASHER
Kenmore 110.18522791  AUTOMATIC WASHER
Kenmore 110.18532790  AUTOMATIC WASHER
Kenmore 110.18542891  AUTOMATIC WASHER
Kenmore 110.18609890  AUTOMATIC WASHER
Kenmore 110.18702790  AUTOMATIC WASHER
Kenmore 110.18702791  AUTOMATIC WASHER
Kenmore 110.19101990  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101991  AUTOMATIC WASHER-GALAXY
Kenmore 110.19101992  WASHER
Kenmore 110.19202200  AUTOMATIC WASHER-GALAXY
Kenmore 110.19422200  AUTOMATIC WASHER-GALAXY
Kenmore 110.20052991  WASHER
Kenmore 110.20052992  WASHER
Kenmore 110.20052993  AUTOMATIC WASHER
Kenmore 110.20056993  AUTOMATIC WASHER
Kenmore 110.20112000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.2011200A  WASHER
Kenmore 110.20132000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20132001  WASHER
Kenmore 110.20172000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20172001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.20272000  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.20272001  COMMERICAL AUTOMATIC WASHER
Kenmore 110.26051690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26058690  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.26071690  COMMERCIAL WASHER
Kenmore 110.26071691  COMMERCIAL WASHER
Kenmore 110.26622690  WASHER
Kenmore 110.26702690  AUTOMATIC WASHER
Kenmore 110.26712690  WASHER
Kenmore 110.26808690  WASHER
Kenmore 110.26809690  AUTOMATIC WASHER
Kenmore 110.26902690  AUTOMATIC WASHER
Kenmore 110.26952690  AUTOMATIC WASHER
Kenmore 110.27802690  AUTOMATIC WASHER
Kenmore 110.279119  BURNER ASSEMBLY 60 HZ
Kenmore 110.279121  BURNER ASSEMBLY 50 HZ
Kenmore 110.27982790  AUTOMATIC WASHER
Kenmore 110.2870090  AUTOMATIC WASHER
Kenmore 110.29012990  COMMERICAL AUTOMATIC WASHER
Kenmore 110.29032990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.29072990  COMMERCIAL AUTOMATIC WASHER
Kenmore 110.3360630  GEARCASE
Kenmore 110.3360631  GEARCASE ASSEMBLY
Kenmore 110.3363361  GEARCASE
Kenmore 110.3387617  BURNER ASSEMBLY
Kenmore 110.3397617  BURNER ASSEMBLY
Kenmore 110.3398423  GAS BURNER
Kenmore 110.3401771  LAUNDRY SUB ASSEMBLIES
Kenmore 110.3401772  BURNER ASSEMBLY
Kenmore 110.3401795  3401795 BURNER ASSEMBLY
Kenmore 110.3401796  GAS DRYER BURNER
Kenmore 110.3401797  GAS BURNER ASSEMBLY
Kenmore 110.3401798  GAS DRYER BURNER
Kenmore 110.3401799  GAS DRYER BURNER ASSEMBLY
Kenmore 110.3402243  BURNER ASSEMBLY
Kenmore 110.3402844  BURNER ASSEMBLY
Kenmore 110.3402851  BURNER ASSEMBLY
Kenmore 110.3402855  BURNER ASSEMBLY
Kenmore 110.3402856  BURNER ASSEMBLY
Kenmore 110.341566  BURNER ASSEMBLY
Kenmore 110.343114  BURNER ASSEMBLY
Kenmore 110.344612  BURNER ASSEMBLY
Kenmore 110.344613  BURNER ASSEMBLY
Kenmore 110.349621  BURNER ASSEMBLY 60 HZ
Kenmore 110.349797  BURNER ASSEMBLY 60 HZ
Kenmore 110.349798  BURNER ASSEMBLY
Kenmore 110.349799  BURNER ASSEMBLY 60 HZ
Kenmore 110.349832  BURNER ASSEMBLY 50 HZ
Kenmore 110.349833  BURNER ASSEMBLY
Kenmore 110.349834  BURNER ASSEMBLY 50 HZ
Kenmore 110.349835  BURNER ASSEMBLY 50 HZ
Kenmore 110.357176  GEARCASE ASM
Kenmore 110.358486  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358488  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358519  GEARCASE AND SUPERSTRUCTURE
Kenmore 110.358794  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.359054  GEAR CASE AND SUPER STRUCTURE
Kenmore 110.359055  GEAR CASE AND SUPERSTRUCTURE
Kenmore 110.362140  GEAR CASE AND SUPERSTRUCTURE ASSEMBLY
Kenmore 110.42182200  AUTOMATIC WASHER
Kenmore 110.42182201  AUTOMATIC WASHER
Kenmore 110.42722200  AUTOMATIC WASHER
Kenmore 110.42722201  AUTOMATIC WASHER
Kenmore 110.42822200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42822201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42824200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42824201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42826200  AUTOMATIC WASHER, COMPACT A/W
Kenmore 110.42826201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42832200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42832201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42834200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Kenmore 110.42834201  AUTOMATIC WASHER HORIZONTAL AXIS
Kenmore 110.42836200  AUTOMATIC WASHER W/HORIZONTAL AXIS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Oasis no power Ron T Washer Repair 2 05-05-2011 07:36 AM
help with kenmore elite oasis washer tdavid64 Washer Repair 9 01-01-2010 03:05 PM
F1 code Kenmore elite oasis toploading washer JuliaD Washer Repair 1 11-17-2009 04:48 PM
F1 on Kenmore Elite Oasis easyrider812 Washer Repair 4 10-05-2009 10:01 AM
kenmore clothes washer, elite/ oasis wapiwulo Washer Repair 1 09-23-2009 09:59 AM
