Discuss
Control Board Replacement???
 in
Washer Repair
Hello. I have a Maytag Front Loading Washer that all of a sudden the control buttons don't seem to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Control Board Replacement???
  #1 (permalink)
Old 09-09-2009, 06:02 AM
suzim424 suzim424 is offline
Junior Member
suzim424 is on a distinguished road
Default Control Board Replacement???
Model Number: MAH5500BWW   Brand: Maytag   Age: 5 - 10 years
Hello. I have a Maytag Front Loading Washer that all of a sudden the control buttons don't seem to work properly. Yesterday all the normal buttons (warm/warm setting, cycle desired, signal button, on/pause) were blinking and would not respond when I hit any of them nor would they shut off. I tried various troubleshooting techniques that I guessed would help, shutting off the power, etc., and it didn't work. Today I plugged it in after being unplugged overnight and was able to hit start and the cycle began. Unfortunately it wasn't entirely normal as the buttons seemed to push/switch on their own - changing warm/warm to warm/cold, changing normal cycle to light cycle, etc. while the water was filling. In the end, the wash cycle ran (not sure if it was normal or light as the buttons flashed most of the cycle) and all else appeared to work fine....the clothes came out clean and all other stages of the wash cycle seemed ok.
I believe the only thing wrong is the control board and want to see if this sounds right before I order the new part and try to find someone to swap them out for me.
Any thoughts???
Related Models
Maytag MAH5500BWW Washer - Horizontal Axis
Maytag MAH55FLBWQ Washer - Horizontal Axis
Maytag MAH55FLBWW Washer - Horizontal Axis
Maytag MAH6500AWQ Washer - Horizontal Axis
Maytag MAH6500AWW Washer - Horizontal Axis
Maytag MAH6700AWM Washer - Horizontal Axis
Maytag MAH6700AWW Washer - Horizontal Axis
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
Maytag MAT23PCABG Washer - Top Loading
Maytag MAT23PCABL Washer - Top Loading
Maytag MAT23PCABW Washer - Top Loading
Maytag MAT25CSAAG Washer - Top Loading
Maytag MAT25CSAAL Washer - Top Loading
Maytag MAT25CSAAW Washer - Top Loading
Maytag MAT25CSAGG Washer - Top Loading
  #2 (permalink)
Old 09-10-2009, 05:35 PM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
Unfortunately this problem can be the control board, or the console LED display board. Both are expensive, and unless you can put your machine through a successful diagnostic test you will have to have a tech visit and confrim which item needs to be replaced.
This is going to be expensive, even if you buy the parts yourself and have someone put them in for free, so you may want to consider replacing the machine.
Here is the service manual. Supplemental info on your model, which is a later generation Maytag is at the back.
http://www.servicematters.com/maytag...s/16010061.pdf
Good luck
__________________
  #3 (permalink)
Old 09-11-2009, 06:45 AM
Junior Member
Default
Thank you very much for your response. I went looking for new machines yesterday and heard from Sears that I should consider myself lucky for getting 7 1/2 years out of my Neptune due to issues they had. Unfortunate that I paid $1,000 for a top of the line machine at the time and it lasted half of what I expected, but that's the breaks I guess!
Thanks again for your advice.
  #4 (permalink)
Old 09-11-2009, 07:43 AM
Senior Expert
APP Volunteer
Default
Unfortunately they are right. Although your model is an improvement over earlie versions, getting 7+ years from this model is like winning the lottery. These machines have been a disaster for Maytag
I suggest you purchase a no frills, top loading machine. I strongly advise you to avoid any machine with micro processor controls. If you buy one with those, be sure and get the extended service contract.
The no frills top loader will do a great job, last for years, have very little problems and are easy and less expensive to fix.
Good luck.
__________________
  #5 (permalink)
Old 09-11-2009, 07:55 AM
Junior Member
Default
Wow. I'm so surprised with how much I paid. I thought Maytags lasted 20 years! Boy how times have changed.
That's my latest decision. Top load vs. front load. Everything I read and the salesmen all say front load due to less water used and how much dryer the clothes come out so it saves drying time, etc. I LOVED my front loader, but they all have the control boards, which cannot be fixed when they go.
When I went out yesterday I was set on a top load for all the reasons you stated, but the salesmen really don't recommend them.....although it could be because the front loaders are more expensive and they all strongly recommend the service plans, which are from $150-$250 extra.
Thanks for your recommendations. Could you recommend any particular brands? I see LG have a lot and are good priced, but are newer to selling appliances.
  #6 (permalink)
Old 09-11-2009, 08:26 AM
Senior Expert
APP Volunteer
Default
Well, like the late David Brinkley my motto is "everyone is entitled to my opinion" so here it is.
The sales people you are talking with probably know very little about washers, but are likely on commission, meaning they want to steer you to the expensive machine. The front loaders do use less water, and do dry the clothes marginally more, but not enough to come close to justifying their extra price or savings.
In our area you can get a direct drive Roper or Estate for around $300.00. This is the low end Whirlpool machine, but all that means is that it is a Whirlpool washer with Whirlpool parts with a different label. If you are uncomfortable with that, for another $30 or $40 you can get one with the Whirlpool or Kenmore label. (If the Kenmore machine has a 110 at the beginning of the model number, it is a Whirlpool machine; if the number is 417 it is a Frigidaire). The top loading basic GE or Frigidaire or Maytag are also good machines.
Avoid LG. They make great electronics, but their washers border on unfixable. There may be a lot of things wrong with American industry, but we make the best washers and dryers in the world. Really.
The basic machines have all the cycles you need. The extra cycles and settings on the higher priced machines are basically marketing gimmicks, and are only marginally useful. They are mainly things that can go wrong. They remind me of Spinal Tap, whose said their music was better because their amplifiers went up to 11, while everyone else's went up only to 10.
The technology of top loading direct drive machines has been around for 25 years. It works, and has stood the test of time. If you have any qualms get the extended service contract. Then take the money you saved and enjoy yourself.
Well, that's my story and I am sticking to it.
__________________
  #7 (permalink)
Old 09-11-2009, 09:24 AM
Junior Member
Default
I REALLY appreciate your opinion. Thank you so much.
I tend to agree with you, as that is what I was thinking about the commission and "sales" side.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
control board replacement bigdpv Refrigerator & Freezer Repair 0 02-08-2010 12:54 PM
Electric control board replacement mthompson Oven Repair (including Ranges and Cooktops) 6 02-02-2010 08:13 AM
whirlpool control board replacement BarryT Oven Repair (including Ranges and Cooktops) 0 09-08-2009 10:05 AM
Control Board replacement for a GE stove. fireman Oven Repair (including Ranges and Cooktops) 1 08-26-2008 09:28 AM
Maytag control board replacement catsun54 Refrigerator & Freezer Repair 1 09-29-2007 03:55 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
