Discuss
Whirlpool Duet Sport
 in
Washer Repair
I have a Whirlpool Duet Sport washer that doesn't spin or drain properly. When cycle goes into spin , the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet Sport
  #1 (permalink)
Old 05-11-2012, 11:21 AM
Junior Member
tudocomprazer is on a distinguished road
Unhappy Whirlpool Duet Sport
Brand: Whirlpool   Age: 1 - 5 years
I have a Whirlpool Duet Sport washer that doesn't spin or drain properly. When cycle goes into spin , the machine spins very slowly and as a result all the clothes are wet at end of cycle. Even when I put control in drain/spin only I get the same result. I've already been to Whirlpool troubleshooting but there is a lack of information relating directly to spin/drain problems. I'm not sure if its a pump problem or other. Problem is very noticeable if we wash items such as pillows, bathroom rugs, tennis sneakers, heavy duty items, etc. We don't overload our machine but it simply doesn't seem to spin or drain at correct speed anymore. Can someone give me a hint at what to check. Thank you.
Ads By Google
  #2 (permalink)
Old 05-14-2012, 05:48 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Look under the top or inside the lower service panel and you should find some tech notes that will show you how to generate error codes.
These Duets are very hard to diagnose, a lot of time you just end up replacing components one by one until you fix it. Sometimes you don't even fix it.
__________________
  #3 (permalink)
Old 05-14-2012, 06:52 PM
Junior Member
Default
Thank you to those who replied. Unfortunately I paid for advice on just answers.com before anyone here could answer. Sure enough my problem was a clogged drain filter before the pump inlet. There are plenty of You Tube Videos on how to fix this and I did fix the problem (bobby pins, coins, plastic junk found in filter). By the way, I see nothing but complaints about Whirlpool Duet machines and NOBODY SHOULD BUY THESE MACHINES, THEY SUCK. Thank goodness these aren't my machines
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Sport CCU tencmn Washer Repair 12 01-21-2013 10:08 AM
Whirlpool Duet Sport rmach Washer Repair 1 01-04-2012 01:41 PM
Whirlpool Duet Sport rmach Washer Repair 1 01-04-2012 08:41 AM
Whirlpool Duet Sport srlunds Washer Repair 5 08-01-2011 09:48 AM
Whirlpool Duet Sport P.O.S.(s) bigbluesupercrew Washer Repair 1 09-12-2010 03:25 AM
