I Have A Problem With A Frigidaire Stackable Washer/dryer. It Fills With Water, Then Nothing. If I Advance The Timer, I Will Drain And Spin. I Can Not Get It To Agitate. Thought It Was The Timer. Checked The Water Level Switch.can't Find The Schamtic. Help !!!!!!!!
SLIMSP1@YAHOO.COMOriginally Posted by: slimsp1 I Have A Problem With A Frigidaire Stackable Washer/dryer. It Fills With Water, Then Nothing. If I Advance The Timer, I Will Drain And Spin. I Can Not Get It To Agitate. Thought It Was The Timer. Checked The Water Level Switch.can't Find The Schamtic. Help !!!!!!!!
