Discuss
Amana washer broken belt, not turning, leaks from bottom
 in
Washer Repair
It's my elderly mother's washer, approximately 7 yrs old. It wasn't turning. I took the front panel
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Amana washer broken belt, not turning, leaks from bottom
  #1 (permalink)
Old 09-08-2009, 11:13 AM
JonTK JonTK is offline
Junior Member
JonTK is on a distinguished road
Default Amana washer broken belt, not turning, leaks from bottom
Model Number: LW8303L2   Brand: Amana   Age: 5 - 10 years
It's my elderly mother's washer, approximately 7 yrs old. It wasn't turning. I took the front panel off and notice that the belt was broken and thought that to be an easy fix. I got a replacement belt, but because I did not have to take the old one off, I did not realize that it had an idler or tensioner pulley.
I replaced just the belt. The motor turned and the tub turned somewhat in testing, but in spin cycle it does not. Manually turning the tub from either the agitator above or pulley below was difficult. The pulley and the brakes were rusty. Once I was able to manually turn the tub, I put the belt on and retested, but got the same results, only this time the tub was leaking from beneath.
I dismantled the machine down to the outer tub. There was what looked to be a sediment filter, but no discernable way to remove the filter and I could not see the seal.
My questions are: Could these three problems (broken belt, leak at the bottom & tub not turning) be related?
What would the most logical course of diagnosis or repair be?
Thank you in advance for your help in this matter.
Related Models
Amana LW8303L2 Washer - Top Loading
Amana LW8303W2 Washer - Top Loading
Amana LW8312L2 Washer - Top Loading
Amana LW8312W2 Washer - Top Loading
Amana LW8363L2 Washer - Top Loading
Amana LW8363W2 Washer - Top Loading
Amana LW8403W Washer - Top Loading
Amana LW8413L2 Washer - Top Loading
Amana LW8413W2 Washer - Top Loading
Amana LW8413W2B Washer - Top Loading
Amana LW8463L2 Washer - Top Loading
Amana LW8463W2 Washer - Top Loading
Amana LW9003 Washer - Top Loading
Amana LW9103 Washer - Top Loading
Amana LW9103W Washer - Top Loading
Amana LW9203L2 Washer - Top Loading
Amana LW9203W Washer - Top Loading
Amana LW9203W2 Washer - Top Loading
Amana LWA05AW Washer - Top Loading
Amana LWA10AW Washer - Top Loading
Amana LWA18AW Washer - Top Loading
Amana LWA20AW Washer - Top Loading
Amana LWA30AL Washer - Top Loading
Amana LWA30AW Washer - Top Loading
Amana LWA30BL Washer - Top Loading
Amana LWA30BW Washer - Top Loading
Amana LWA40AL Washer - Top Loading
Amana LWA40AL2 Washer - Top Loading
Amana LWA40AW Washer - Top Loading
Amana LWA40AW2 Washer - Top Loading
Whirlpool LWA4800W1
Amana LWA50AL Washer - Top Loading
Amana LWA50AW Washer - Top Loading
Whirlpool LWA5300W0
Whirlpool LWA5300W1
Whirlpool LWA5300W2
Whirlpool LWA5300W3
Whirlpool LWA5304W0
Whirlpool LWA5304W1
Whirlpool LWA5304W2
Whirlpool LWA5304W3
Whirlpool LWA5305W0
Whirlpool LWA5305W1
Whirlpool LWA5305W2
Whirlpool LWA5305W3
Whirlpool LWA5309W0
Whirlpool LWA5309W1
Whirlpool LWA5309W2
Whirlpool LWA5309W3
Whirlpool LWA5500W0
Whirlpool LWA5500W1
Whirlpool LWA5505W0
Whirlpool LWA5505W1
Whirlpool LWA5540W0
Whirlpool LWA5540W2
Whirlpool LWA5540W3
Whirlpool LWA5545W0
Whirlpool LWA5545W2
Whirlpool LWA5545W3
Whirlpool LWA5560W3
Whirlpool LWA5565W3
Whirlpool LWA5800W0
Whirlpool LWA5800W1
Whirlpool LWA5800W2
Amana LWA60AL Washer - Top Loading
Amana LWA60AW Washer - Top Loading
Whirlpool LWA6400W0
Whirlpool LWA6400W2
Whirlpool LWA6400W3
Whirlpool LWA6400W4
Whirlpool LWA6400W5
Whirlpool LWA6400W6
Whirlpool LWA6404W0
Whirlpool LWA6404W2
Whirlpool LWA6404W3
Whirlpool LWA6404W4
Whirlpool LWA6405W0
Whirlpool LWA6405W2
  #2 (permalink)
Old 09-08-2009, 12:15 PM
Frank / APP Team's Avatar
Frank / APP Team Frank / APP Team is offline
Senior Expert
Frank / APP Team is on a distinguished road
Default
Yes they can.
There should be 8 bolts, if memory serves me right holding the lint filter in place. Under that you can then get to the seal and bearing assembly.
Sometimes it doesn't come a part real easily. Use the below link and look at page 2 and 3 and you will see the breakdown of the parts. Something you will need to verify before ordering parts is the Manufacturer #, it's on the ID plate where the model # was.
Model LW8303L2
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-12-2009, 12:20 PM
Junior Member
Default
Thanks Frank.. Actually the filter just pried off. Now there is the spline, a rubber covered black object and 2 metal plates, but I see no way to get them off. I took out the entire outter tub thinking i have to release them from the bottom. There are 3 or 4 nuts/bolts, but I cant seem to reach them because of the transmission. BTW the Manufacturer is PLW8303L2 B.
Thanks for any help you can give me.
Jk
  #4 (permalink)
Old 09-12-2009, 03:04 PM
Junior Member
Default
Well, I got further. There was a rubber seal that goes over the locknut and washer. There is this metle sprocket type tab washer that looks to be holding down the nut. I cannot budge the nut at all. I assume that this is a reverse thread nut. Does that washer thingy with the tabs need to be taken out or punched down or what? Should I just let some penetrating oil soak over night and try again in the morning?
Any help any one can give me I would appreciate it.
Thank you!
  #5 (permalink)
Old 09-12-2009, 03:14 PM
Junior Member
Default
One more thing... How would I know if the brake pads or idler pulley need to be replaced?
  #6 (permalink)
Old 09-13-2009, 12:45 PM
Junior Member
Default
Finally!! I got the nut off. The spline washer has nothing really to do with it. One big important note.. on this washer, it is regular threaded, so it comes off turning counter-clockwise. I applied heat, hit it with a hammer then soaked it in liquid wrench for about 2 hours. Now that I have the nut off, to what end? I still can't get to the seal. If anyone has any ideas, I would appreciate it.
  #7 (permalink)
Old 09-14-2009, 07:05 AM
Senior Expert
Default
The hub itself is splined, don't know if that's what you're now looking at or not. Below is a picture of the hub and seal kit, along with a link to your model. Maybe they will help you out.
Part number: AP4253981
Model AP4253981
__________________
  #8 (permalink)
Old 09-14-2009, 03:52 PM
Junior Member
Default
Thanks again Frank. It looks kind of sort of like the larger item in the upper left corner of the picture. So I guess that's the hub. I probably have to pull it off with a gear puller. Does that sound correct?
In looking at that picture, do you think I have to replace all of those parts? I have already pulled most of those parts and they don't look as though they have failed.
Thanks,
JK
  #9 (permalink)
Old 09-15-2009, 05:46 AM
Senior Expert
Default
Thanks,
JK
What you see comes as a kit. That's the way it's sold.
I'm sure it's just gunked up from water, soap, and grime. Have you tried the penetrating oil on it? A puller may have to come into play.
__________________
  #10 (permalink)
Old 09-15-2009, 06:31 AM
Junior Member
Default
Thank you Frank.. I did hit it hard with liquid wrench. I guess I'll get a gear puller and try it that way. I appreciate all of your help and support.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana washer leaks richromaine Washer Repair 1 08-20-2009 06:19 PM
Washer Fills, but leaks out of the bottom QTBaby21 Washer Repair 1 07-09-2009 01:30 PM
washer leaks water out bottom jag11727 Washer Repair 3 05-12-2009 11:26 AM
Kitchen Aid dish washer leaks from door bottom when washing rogerelm Dishwasher Repair 2 04-15-2009 03:15 PM
Washer sometimes leaks bottom front left liseglaz Washer Repair 0 02-02-2008 09:38 AM
