Discuss
70 series kenmore wont spin
 in
Washer Repair
have a 70 series kenmore washer, model number 82672110 that does everything right till the rince cycle. it drains the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 70 series kenmore wont spin
  #1 (permalink)
Old 09-08-2009, 09:10 AM
Junior Member
nikko is on a distinguished road
Default 70 series kenmore wont spin
Model Number: 82672110   Brand: Kenmore   Age: 5 - 10 years
have a 70 series kenmore washer, model number 82672110 that does everything right till the rince cycle. it drains the water, motor sounds normal like it's spinning but when you open it nothing is moving so the clothes are still very wet at the end. checked the motor coupling and looks almost new. there is a belt of some sort up underneath behind the motor that is worn, loose and appears to not be connected to anything. is this the problem and how do we fix it. thanks
Ads By Google
Related Models
Amana 827.000 Range - S/c S/i Ddraft Gas
Amana 827.301 Range - S/c S/i Ddraft Gas
Amana 8272.A Mwave - Family Size (60 Hz)
Amana 8272.B Mwave - Family Size (60 Hz)
Amana 8275.A Mwave - Family Size (60 Hz)
Amana 8276.A Mwave - Family Size (60 Hz)
Amana 8276.B Mwave - Family Size (60 Hz)
Amana 8291.A Mwave - Family Size (60 Hz)
Amana 8294.A Mwave - Family Size (60 Hz)
Amana 8294.B Mwave - Family Size (60 Hz)
Magic Chef 82FA-1 Surface Unit - Gas
Magic Chef 82FA-12 Surface Unit - Gas
Magic Chef 82FA-12K Surface Unit - Gas
Magic Chef 82FA-1K Surface Unit - Gas
Magic Chef 82FG-1K Surface Unit - Gas
Magic Chef 82FK-1
Magic Chef 82FK-1K Surface Unit - Gas
Magic Chef 82FN-1 Surface Unit - Gas
Magic Chef 82FN-1K Surface Unit - Gas
Magic Chef 82FS-1 Surface Unit - Gas
Magic Chef 82FS-12 Surface Unit - Gas
Magic Chef 82FS-12K Surface Unit - Gas
Magic Chef 82FS-1K Surface Unit - Gas
Magic Chef 82FY-1 Surface Unit - Gas
Magic Chef 82FY-1K
Magic Chef 82HA-1 Surface Unit - Gas
Magic Chef 82HA-12 Surface Unit - Gas
Magic Chef 82HA-1K Surface Unit - Gas
Magic Chef 82HA-2K Surface Unit - Gas
Magic Chef 82HN-1 Surface Unit - Gas
Magic Chef 82HN-1K Surface Unit - Gas
Magic Chef 82HN-2K Surface Unit - Gas
Magic Chef 82HS-1
Magic Chef 82HS-1K
Magic Chef 82HS-2K Surface Unit - Gas
Magic Chef 82HW-1K
Magic Chef 82HY-1K
Magic Chef 82JA-2K Surface Unit - Gas
Magic Chef 82JK-2K
Magic Chef 82JN-2K Surface Unit - Gas
Magic Chef 82JS-2K
Magic Chef 82LA-1 Surface Unit - Gas
Magic Chef 82LA-2K Surface Unit - Gas
Magic Chef 82LK-2K Surface Unit - Gas
Magic Chef 82LK-3K Surface Unit - Gas
Magic Chef 82LN-1 Surface Unit - Gas
Magic Chef 82LN-2K Surface Unit - Gas
Magic Chef 82LN-3K Surface Unit - Gas
Magic Chef 82LS-1 Surface Unit - Gas
Magic Chef 82LS-2K Surface Unit - Gas
Magic Chef 82LW-2K Surface Unit - Gas
Magic Chef 8311PA Surface Unit - Gas
Magic Chef 8311PS Surface Unit - Gas
Magic Chef 8311PW Surface Unit - Gas
Magic Chef 8311TA Surface Unit - Gas
Magic Chef 8311TS Surface Unit - Gas
Magic Chef 8311TW Surface Unit - Gas
Magic Chef 8320PA Surface Unit - Gas
Magic Chef 8320PB
Magic Chef 8320PS Surface Unit - Gas
Magic Chef 8320PW Surface Unit - Gas
Magic Chef 8320TA Surface Unit - Gas
Magic Chef 8320TS Surface Unit - Gas
Magic Chef 8320TW Surface Unit - Gas
Magic Chef 8321PA Surface Unit - Gas
Magic Chef 8321PB Surface Unit - Gas
Magic Chef 8321PS Surface Unit - Gas
Magic Chef 8321PW Surface Unit - Gas
Magic Chef 8321TA Surface Unit - Gas
Magic Chef 8321TB Surface Unit - Gas
Magic Chef 8321TS Surface Unit - Gas
Magic Chef 8321TW Surface Unit - Gas
Whirlpool 8340NFSBS00
Magic Chef 8341VB Surface Unit - Gas
Magic Chef 8341VD Surface Unit - Gas
Magic Chef 8341VS Surface Unit - Gas
Magic Chef 8341VV Surface Unit - Gas
Magic Chef 8351VB Surface Unit - Gas
Magic Chef 8351VD Surface Unit - Gas
Magic Chef 8351VQ Surface Unit - Gas
Magic Chef 8351VS Surface Unit - Gas
Magic Chef 8351VV Surface Unit - Gas
Magic Chef 8361RB Surface Unit - Gas
Magic Chef 8361RV Surface Unit - Gas
Magic Chef 8361RW Surface Unit - Gas
Magic Chef 83EA-1 Surface Unit - Gas
Magic Chef 83EA-1G Surface Unit - Gas
Magic Chef 83EA-1GK Surface Unit - Gas
Magic Chef 83EA-1K Surface Unit - Gas
Magic Chef 83EB-1G Surface Unit - Gas
Magic Chef 83EB-1GK Surface Unit - Gas
Magic Chef 83EN-1 Surface Unit - Gas
Magic Chef 83EN-1G Surface Unit - Gas
Magic Chef 83EN-1GK Surface Unit - Gas
Magic Chef 83EN-1K Surface Unit - Gas
Magic Chef 83EP-1GK Surface Unit - Gas
Magic Chef 83ES-1 Surface Unit - Gas
Magic Chef 83ES-1G Surface Unit - Gas
Magic Chef 83ES-1GK Surface Unit - Gas
Magic Chef 83ES-1K Surface Unit - Gas
Magic Chef 83ET-1GK
Magic Chef 83EY-1 Surface Unit - Gas
Magic Chef 83EY-1GK
Magic Chef 83FA-1 Surface Unit - Gas
Magic Chef 83FA-1G Surface Unit - Gas
Magic Chef 83FA-1GK Surface Unit - Gas
Magic Chef 83FA-1K Surface Unit - Gas
Magic Chef 83FG-1K Surface Unit - Gas
Magic Chef 83FK-1 Surface Unit - Gas
Magic Chef 83FN-1 Surface Unit - Gas
Magic Chef 83FN-1G Surface Unit - Gas
Magic Chef 83FN-1GK Surface Unit - Gas
Magic Chef 83FN-1K Surface Unit - Gas
Magic Chef 83FS-1 Surface Unit - Gas
Magic Chef 83FS-1G Surface Unit - Gas
Magic Chef 83FS-1GK Surface Unit - Gas
Magic Chef 83FS-1K Surface Unit - Gas
Magic Chef 83FY-1GK Surface Unit - Gas
Magic Chef 83HA-1 Surface Unit - Gas
Magic Chef 83HA-1G Surface Unit - Gas
  #2 (permalink)
Old 09-10-2009, 02:12 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Since there is no belt on this model, I think what you are seeing is a piece of the motor coupling.
You have to disassmble it to really inspect. I suggest you do this, and if the coupling is bad replace. If not report back what you found and what you think the belt piece was and we will come up with something else.
__________________
  #3 (permalink)
Old 09-11-2009, 09:34 AM
Junior Member
Default
already did that and the coupler is fine. the belt thing looks like a belt 6 - 8 inches long, maybe it's some kind of gasket or washer of some sort. like i said it's behind the motor up under the the tup part. doesn't appear to actually do anything but it is rather tattered looking. so if it's not the coupler what else can i check? switch is fine also
  #4 (permalink)
Old 09-11-2009, 09:52 AM
Senior Expert
APP Volunteer
Default
Take off the motor, leaving on the wire connection and see if the transmission will turn in a clockwise direction. Also, very briefly plug in the machine and see if the motor runs when it is in spin mode.
If the transmission will turn and the motor runs you probably have a clutch problem. Inspect the drive block on the way to check it as that can be a problem, but is far less likely.
If the transmission will not turn you may have a brake problem. See the sticky by richappy at the top of this Forum. It is very good and very useful.
I don't know what that piece is that you found.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 80 series won't spin Mike Ganoe Washer Repair 1 05-17-2009 11:28 AM
kenmore 80 series wont spin spacecase Washer Repair 1 03-09-2009 03:41 PM
kenmore washer 70 series wont spin and drain water foster13019 Washer Repair 1 12-20-2008 01:05 PM
Kenmore washer 90 plus series wont spin Mark Renfrow Washer Repair 1 10-24-2008 08:58 PM
Kenmore 60 Series(gas) Runs but wont heat PJM Dryer Repair 0 02-02-2008 06:09 AM
