Washer will not drain. Removed pump and did not find any thing in it. I can hear the pump humming. Checked pump ohms and it was 14. Checked pump power in when it was humming and it was 23.5 volts. Any Ideas
Groups: APP Team
Hi. Open the control panel, locate the P4 plug at the machine control. Check the connection and harness. Set washer for drain and check for 120VAC at P4. No voltage - replace the machine control Part number: W10249237
