I have a two speed top load washer. It doesn't want to completely spin out. The clothes are not dripping with water but they are not as spun out as they should be. Could it be a belt or a problem with the motor? I tried checking the owner's guide on your site but I didn't see a belt. I have thought about selling it but wasn't sure what it might cost to fix the problem. Thanks
This sounds like it could be a slipping clutch....Not releasing the brake completely not alowing max rpm s
