There's just too much lint on my clothes even if I'm just washing darks. This washer is suppose to have a self-cleaning lint filter, and there are no filter plugs to replace. Drain pump and hoses are clear. What could be the problem?
I have the same problem. White lint on black clothes, black lint on white clothes.
Were you able to resolve the problem?
No. Lint is still an issue. I just make sure I'm not over loading the wash and to use enough water to that lint is rinsed off properly. I'll also separate anything that will seems to catch lint, ie jeans separate from the rest of the coloreds. Cottons separate from polyesters.
