Kenmore Series 80 Washer Won't Spin
Washer Repair
Hey all, I apologize for posting on what appears to be a common problem, but I've done quite a bit
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Series 80 Washer Won't Spin
  #1 (permalink)
Old 05-06-2012, 08:05 PM
Junior Member
dalejamin is on a distinguished road
Default Kenmore Series 80 Washer Won't Spin
Model Number: 11027802690   Brand: Kenmore   Age: 5 - 10 years
Hey all,
I apologize for posting on what appears to be a common problem, but I've done quite a bit of research on the issue over the weekend and am unable to find a conclusive answer. Everything else works ok; it agitates and drains. Hoever, during the spin cycle, the washer stops spinning. I tested the lid switch and pulled the coupler. The switch is ok, and the coupler is intact but worn. Niether plastic piece of the coupler fits tight; they each slide off with relatively ease. At the point when the tub stops spinning, I can here a noise that sounds like something is separating. The tub stops spinning, but I can hear the motor continue to turn. When I pull the motor, the entire coupler assembly comes out; I think it's always on the motor shaft (has been the last two times I've pulled it for sure). I reinstall and everything works fine until the next spin cycle. Within 2 to 3 minutes into the spin cycle, the tub stops spinning. I've done this (pulled and reinstalled) several times.
My question is, is the problem that the coupler is loose and worn, or is the issue in either the gearcase or motor?
Thanks in advance!
Related Models
Kenmore 11027802690 AUTOMATIC WASHER
Kenmore 11027802691 AUTOMATIC WASHER
Kenmore 11027812690 AUTOMATIC WASHER
Kenmore 11027812691 AUTOMATIC WASHER
Kenmore 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Kenmore 11027824790 AUTOMATIC WASHER
Kenmore 11027831600 RESIDENTIAL WASHER
Kenmore 11027841600 RESIDENTIAL WASHERS
Kenmore 11027852790 AUTOMATIC WASHER
Kenmore 11027852791 AUTOMATIC WASHER
Kenmore 11027862790 AUTOMATIC WASHER
Kenmore 11027871600 RESIDENTIAL WASHERS
Kenmore 11027872600 RESIDENTIAL WASHERS
Kenmore 11027874600 RESIDENTIAL WASHERS
Kenmore 11027892790 AUTOMATIC WASHER
Kenmore 11027892791 AUTOMATIC WASHER
Kenmore 11027894790 AUTOMATIC WASHER
Kenmore 11027894791 AUTOMATIC WASHER
Kenmore 11027902790 AUTOMATIC WASHER
Kenmore 11027982790 AUTOMATIC WASHER
Kenmore 11028002010 AUTOMATIC WASHER
Kenmore 11028002011 AUTOMATIC WASHER
Kenmore 11028012010 AUTOMATIC WASHER
Kenmore 11028012011 AUTOMATIC WASHER
Kenmore 11028032700 RESIDENTIAL WASHER
Kenmore 11028032701 RESIDENTIAL WASHER
Kenmore 11028042700 RESIDENTIAL WASHER
Kenmore 11028042701 WASHER
Kenmore 11028062800 RESIDENTIAL WASHER
Kenmore 11028072800 RESIDENTIAL WASHER
Kenmore 11028081700 WASHER
Kenmore 11028082700 RESIDENTIAL WASHER
Kenmore 11028087700 RESIDENTIAL WASHER
Kenmore 11028091700 WASHER
Kenmore 11028092700 RESIDENTIAL WASHER
Kenmore 11028097700 WASHER
Kenmore 11028222700 RESIDENTIAL WASHER
Kenmore 11028222701 WASHER
Kenmore 11028299890 AUTOMATIC WASHER
Kenmore 11028322700 RESIDENTIAL WASHER
Kenmore 11028332700 RESIDENTIAL WASHER
Kenmore 11028352700 RESIDENTIAL WASHER
Kenmore 11028362700 RESIDENTIAL WASHER
Kenmore 11028372700 RESIDENTIAL WASHER
Kenmore 11028422700 RESIDENTIAL WASHER
Kenmore 11028432700 RESIDENTIAL WASHER
Kenmore 11028522700 RESIDENTIAL WASHER
Kenmore 11028522701 RESIDENTIAL WASHER
Kenmore 11028532700 RESIDENTIAL WASHER
Kenmore 11028532701 RESIDENTIAL WASHER
Kenmore 11028622700 RESIDENTIAL WASHER
Kenmore 11028622701 RESIDENTIAL WASHER
Kenmore 11028632700 RESIDENTIAL WASHER
Kenmore 11028632701 RESIDENTIAL WASHER
Kenmore 11028692700 RESIDENTIAL WASHER
Kenmore 11028692701 RESIDENTIAL WASHER
Kenmore 1102870090 AUTOMATIC WASHER
Kenmore 11028722700 RESIDENTIAL WASHER
Kenmore 11028732700 RESIDENTIAL WASHER
Kenmore 11028752700 RESIDENTIAL WASHER
Kenmore 11028762700 RESIDENTIAL WASHER
Kenmore 11028782700 RESIDENTIAL WASHER
Kenmore 11028802890 AUTOMATIC WASHER
Kenmore 11028803890 AUTOMATIC WASHER
Kenmore 11028812790 AUTOMATIC WASHER
Kenmore 11028822790 AUTOMATIC WASHER
Kenmore 11028822791 AUTOMATIC WASHER
Kenmore 11028824790 AUTOMATIC WASHER
Kenmore 11028824791 AUTOMATIC WASHER
Kenmore 11028832700 RESIDENTIAL WASHER
Kenmore 11028837700 RESIDENTIAL WASHER
Kenmore 11028842700 RESIDENTIAL WASHER
Kenmore 11028847700 RESIDENTIAL WASHER
Kenmore 11028872890 AUTOMATIC WASHER
Kenmore 11028872891 AUTOMATIC WASHER
Kenmore 11028874890 AUTOMATIC WASHER
Kenmore 11028874891 AUTOMATIC WASHER
Kenmore 11028882790 AUTOMATIC WASHER
Kenmore 11028882791 AUTOMATIC WASHER
Kenmore 11028884790 AUTOMATIC WASHER
Kenmore 11028884791 AUTOMATIC WASHER
Kenmore 11028892790 AUTOMATIC WASHER
Kenmore 11028892791 AUTOMATIC WASHER
Kenmore 11028894790 AUTOMATIC WASHER
Kenmore 11028894791 AUTOMATIC WASHER
Kenmore 11028902790 AUTOMATIC WASHER
Kenmore 11028902791 AUTOMATIC WASHER
Kenmore 11028912790 AUTOMATIC WASHER
Kenmore 11028912791 AUTOMATIC WASHER
Kenmore 11028922790 AUTOMATIC WASHER
Kenmore 11028922791 AUTOMATIC WASHER
Kenmore 11028924790 AUTOMATIC WASHER
Kenmore 11028924791 AUTOMATIC WASHER
Kenmore 11028932790 AUTOMATIC WASHER
Kenmore 11028932791 AUTOMATIC WASHER
Kenmore 11028934790 AUTOMATIC WASHER
Kenmore 11028934791 AUTOMATIC WASHER
Kenmore 11028942890 Residential Washers
Kenmore 11028942891 AUTOMATIC WASHER
Kenmore 11028944890 Residential Washers
Kenmore 11028944891 AUTOMATIC WASHER
Kenmore 11028972890 AUTOMATIC WASHER
Kenmore 11028972891 AUTOMATIC WASHER
Kenmore 11028974890 AUTOMATIC WASHER
Kenmore 11028974891 AUTOMATIC WASHER
Kenmore 11029422800 RESIDENTIAL WASHER
Kenmore 11029422801 RESIDENTIAL WASHER
Kenmore 11029432800 WASHER
Kenmore 11029432801 RESIDENTIAL WASHER
Kenmore 11029442800 RESIDENTIAL WASHER
Kenmore 11029442801 RESIDENTIAL WASHER
Kenmore 11029522800 RESIDENTIAL WASHER
Kenmore 11029522801 RESIDENTIAL WASHER
Kenmore 11029532800 RESIDENTIAL WASHER
Kenmore 11029532801 RESIDENTIAL WASHER
Kenmore 11029592800 RESIDENTIAL WASHER
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 90 series washer won't agitate or spin purplesunv Washer Repair 14 01-31-2014 09:10 AM
Kenmore washer series 90 spin problem Toby1 Washer Repair 7 08-10-2011 04:49 AM
Kenmore 80 Series Washer Won't Spin lbunay Dishwasher Repair 3 09-16-2010 07:31 AM
Kenmore Series 80 washer won't spin cwenzel Dishwasher Repair 0 09-05-2010 03:13 PM
Kenmore Series 70 Washer will not Spin syeager Washer Repair 1 06-02-2009 06:02 PM
