Maytag Washer MAV6200AWW is making whining noise in spin and agitation cycles. All functions are working normally. What might be the problem
Noises like that are almost impossible for us to diagnose without being there, but we can make some suggestions.
The first is to take the front off and check the pump to see if that is the problem. Then operate it with the front off and see if you can determine where the noise is coming from.
It is unusual to have a noise in both agitate and spin, so take a good look at the motor and belt while you have it open.
