W232777e
#1 Posted : Friday, May 4, 2012 4:35:22 PM(UTC)
W232777e
I have been having filling issues with my washer it does not stop filling at the correct water level. I have replaced the press. Switch, replaced the water valve and the press. Switch hose and is still doing the same thing. Should I replace the control board? Please advise I need to have this repaired.
Wil
sidfink43
#2 Posted : Saturday, May 5, 2012 4:55:47 PM(UTC)
sidfink43
Wow, what you did should have done it.
Try this. With the cabinet off and the pressure hose unhooked from the tub and the hold in the tub plugged, start to fill it. Blow into the hose and see if that stops the water from coming in.
If not, the control unit is the big suspect.
KitchenAid dishwasher filling up when turned off (Dishwasher Repair)
by RinOakland 9/14/2020 8:50:00 AM(UTC)
Dishwasher filling with water and leaking (Dishwasher Repair)
by Texasbrons 11/19/2014 4:19:44 PM(UTC)
Dishwasher filling with dirty water (Dishwasher Repair)
by wrangler_new 10/19/2014 7:43:01 AM(UTC)
Washer Filling but nothing else (Washer Repair)
by Jmzwelch 11/17/2013 4:55:53 AM(UTC)
Dishwasher filling but not cycling (Dishwasher Repair)
by pleasemama 4/2/2012 5:55:23 PM(UTC)
Whirlpool washer filling, but nothing else (Washer Repair)
by Remocat 3/16/2012 12:40:10 PM(UTC)
Washer Filling issue (Washer Repair)
by 1978alton3 5/31/2011 5:23:27 AM(UTC)
washer filling and thats it (Washer Repair)
by Gallaway 1/11/2011 8:46:11 AM(UTC)
Bosch diswasher filling and draining problem (Dishwasher Repair)
by jfiner 4/11/2010 4:35:54 PM(UTC)
Washer filling with water... when not on (Washer Repair)
by kwkenuf 3/22/2010 3:11:36 PM(UTC)
maytag washer filling up than buzzer sounding (Washer Repair)
by 69machrk 2/18/2010 5:01:04 PM(UTC)
hotpoint washer filling too high (Washer Repair)
by curtisladd 1/27/2010 9:53:58 AM(UTC)
washer filling up with water (Washer Repair)
by reggierousseau 5/7/2009 6:52:49 AM(UTC)
Dishwasher filling and then nothing... (Dishwasher Repair)
by kadwowner 12/28/2008 4:44:58 PM(UTC)
door will not latch, dishwasher filling as if door is shut (Dishwasher Repair)
by extremevalues 8/10/2008 8:35:29 PM(UTC)
