| » GE Profile washer does not fast spin |
Model Number: WPRE6100G0WT Brand: GE Age: 1 - 5 years
We had a neutral wire problem at our home and it fried the washer control board. I replaced it with a new part from ApplianceParts Pro. Thank you. The washer goes through all its cycles, including a near final spin and drain, but the clothes are sopping wet as though the tub is not spinning fast enough. There is no light on the motor control board, nor is there a diode on the board where all the drawings say it's supposed to be. The field service routine seems to work fine. What can keep the machine from spinning fast? Thanks, Dan
Hi Dan,
Where did you look for the LED? It must be under the motor's metal drip shield like it's shown at the attached picture or on the right side of the motor. Gene. P.S. Make sure there are no any foreign objects between the inner and outer tubs.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
That's where I thought the LED would be, but there isn't one there. There's a component deep in the board toward the back that looks like it could be a LED but it does not light. Before the power surges in our home, the washer worked beautifully and with the new control board everything functions except the spin speed. Are there two speeds of spin or only one? I set it for longer spin, but the clothes are still drenched at the end of the wash, although the tub is dry. I'll look for something between the tubs. Thanks for the suggestion. Dan |
Hi Dan,
In such situation I would suspect the motor inverter failure. The correction is to replace the motor/inverter assembly. - The motor/inverter assembly Part number: WH20X10058 Gene.
__________________
| Display Modes | |
| Washer does not spin fast enough | TPK | Washer Repair | 2 | 03-03-2013 10:01 AM |
| GE Profile won't spin fast | Tamike87 | Washer Repair | 0 | 12-05-2011 04:47 AM |
| Washer not doing a fast spin | idna | Washer Repair | 2 | 02-04-2011 07:23 AM |
| Washer doesn't spin fast enough | joshiesmom54 | Washer Repair | 0 | 02-03-2010 10:27 AM |
| Washer will not do fast spin | charlie1 | Washer Repair | 1 | 04-15-2009 02:18 PM |
