Constant knocking on Rinse/Spin - Kenmore 90 top loader
Washer Repair
During the spin cycle, there's a steady knocking noise that's seems to be emmitted at 2 beats per second and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Constant knocking on Rinse/Spin - Kenmore 90 top loader
  #1 (permalink)
Old 05-01-2012, 06:57 AM
Junior Member
capon is on a distinguished road
Question Constant knocking on Rinse/Spin - Kenmore 90 top loader
Model Number: 110.20922990   Brand: Kenmore   Age: 5 - 10 years
During the spin cycle, there's a steady knocking noise that's seems to be emmitted at 2 beats per second and begins when the tub starts spinning. The beat doesn't change and continues throughout the spin cycle, regardless of the tub rotation speed. It sounds like it's coming from the bottom of the tub.
I thought it maybe the drive block but after removal, cleaning, & inspection, I'm sure that's not the cause. I removed the cabinet and tried to isolate where the noise is coming from, thinking it's within the clutch but I'm pretty sure that's not it because it's a steady knock even when the clutch begins it's rotation and throughout acceleration to obtain it's constant speed. I replaced the coupling last year and inspected it, but didn't disassemble. Coupling looks intact at each dog as I rotated it. I checked for obvious loose or missing components but everything looks fine. The washer works ok but with the noise, I'm sure it's going to get worse. Any ideas?
Related Models
Hoover 1100
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11012202100 WASHER
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 05-02-2012, 05:14 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Diagnosing noises like this is almost impossible without being there.
I suggest you operate it with the cabinet off by by-passing the lid switch. You may be able to see/hear where the problem is. I would also examine the clutch/brakes, you may have a sticky brake issue.
  #3 (permalink)
Old 05-03-2012, 07:08 AM
Junior Member
Default knocking noise on rinse/spin -kenmore 90 top loader
I practically disassembled the entire unit. I checked the coupling:looks good, checked the clutch: looked ok, checked the drive/brake: was a bit tight but looked ok I guess, rotated transmission: wasn't sure but became a little suspicious. Did some google searches and learned more. Re-assembled and tried again. When on entering drain mode to spin, the tub started draining ok (motor and pump works), but tub/basket didn't rotate. It appeared to be stuck. Actually, it tried to rotate, but abruptly stops, as though the brake is engaged.
I then learned more about the brake and someone suggested to apply lubricant (Sil-Glyde) to the drum. I took it apart, applied Sil-Glyde, re-assembled with a new clutch (because I had already purchased one thinking maybe it was the clutch) and tried again. Same problem. Again back to the google search and started thinking more and more of the transmission. To satisfy my stubborn curiosity, I removed the transmission and separated the case (a little mess on the bench). I discoved that the teeth on the large gear, about 4" dia, were worn away. I believe this gear is a softer material like nylon. Also, the part that travels up and down vertically, engaging the clutch when installed wasn't spring loaded (I wondered what causes this part to engage & disengage). Then I looked more into transmission problems on Kenmore and learned from another post that Whirpool (manufacturer) offers parts to the transmission (pn-3360630) and a kit (388253) for about $15.
I'm looking more into trying to replace the worn gear because it looks pretty simple and easily accessable and with a little more gear oil (about 1 oz lost), I should be back in business. But, if I'm faced with buying a transmission at $180, I'll probably consider replacing the washer.
Any thoughts, comments, opinions?
  #4 (permalink)
Old 05-03-2012, 01:46 PM
Senior Expert
APP Volunteer
I would go ahead and try the kit, but if that does not fix things I think a new basic machine which you can get for about $325 to $350.00 in our area is a better bet than buying a new transmission.
Good luck.
  #5 (permalink)
Old 05-03-2012, 08:36 PM
Junior Member
Default Kenmore 90 headache has been resolved without aspirin
Well, this morning I really got into the mess by studying the transmission's parts breakdown and learning more about its operation and function. I then took it apart and inspected the neutral drive settings and how the $15 kit would benefit. I also looked into the cost of the spin gear (the large nylon I mentioned earlier). Apparently the spin gear is packaged with the pinion and sells for about $75 in addition to the kit. Then I thought, what if it still doesn't correct the problem? Since my confidence wasn't entirely 100%, I got a price on a transmission....$185. So that plus a clutch that I had already installed would set me back about $220. And then what's next? I paid $449 for the machine in Feb 2001. I decided to get another machine and start fresh. I'm favoring a Staber top loading, horizontal axis High Efficiency machine. I think it's well designed (tub supported on both sides), simple, practical, very well made and made in the USA.
I personally know somebody who has one and he introduced me to it when he bought his last year. No problems except for his own fault. Somehow a piece of cloth got caught in the pump causing a shutdown. It took him 15 minutes to isolate the problem (thanks to technical support), remove the obstruction, replace the fuse and that was that. Damn good design if you ask me.
Anyone know about these models or hear anything about them?
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG Top Loader jumps from spin back to Rinse mogannaidoo Washer Repair 0 03-17-2012 01:28 AM
Kenmore Elite TopLoader Spin cycle knocking Smiley1 Washer Repair 1 01-13-2012 06:28 PM
Kenmore won't spin, makes knocking sound. larrycummins Washer Repair 1 08-17-2011 06:00 PM
Frigidaire front loader won't rinse/spin/drain watarski Washer Repair 9 04-16-2010 06:02 AM
Knocking Noise Appears off balance Front loader NERAKNERAK Washer Repair 1 01-16-2010 08:46 AM
