| » No spin and no drain |
Model Number: HAV2360AWW Brand: Maytag Age: 5 - 10 years
tHE MACHINE started by no spin and no drain every now and then to almost all the time to not at all, seems to fill and agitate ok I believe. There was some squealling and squeaking then a smell of rubber to all the time. When I pulled the machine out there was a pile of ground rubber on the front right of the machine.
Hi.
Remove the front panel (using the potty knife unclip the two clips on the top sides). Turn the washer to spin and check if the motor runs. Take the belt off and manually turn the motor, the pump and the transmission pulleys. See if any of are jamming. Rotate the transmission pulley in both directions. In one it agitating, opposite - tub spins. Post the results.Thank you. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. Last edited by Simon / APP Team : 04-30-2012 at 04:32 PM. |
| Display Modes | |
| Washer will only drain if put on "Drain+Spin" cycle. | Arieleno | Washer Repair | 7 | 11-02-2011 07:03 PM |
| washer does not spin, fills up and drain the water nornal but do not spin | leaderman | Washer Repair | 0 | 10-04-2010 02:28 PM |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| HELP: wash cycles won't drain/spin, manual rinse/drain works, manual drain/spin works | cosmo99 | Washer Repair | 1 | 01-27-2010 11:33 AM |
| washer will not drain for 1st spin cycle. Does finish with spin dry | tec6422 | Washer Repair | 1 | 01-23-2009 07:44 AM |
