| » intermittent agitator |
Model Number: 110.26742503 Brand: Kenmore Age: 1 - 5 years
Intermiitent agitator, top and bottom agitators stop, hear gearbox running, coupler good, clutch/brakes seem fine. Can move agitator and it starts to work again, but soon stops, move again, works then stops. Spins fine. Can do a load, but have to constantly reset agitator. Took apart gearbox, found broken spring (part #10 on gearbox parts exploded view). Without totally tearing down gearbox, the rest seems fine. Could this be my problem?? What would be the part # I need to order? Also I removed nylon gear to inspect (#25), is there any special procedure to reinstall (alignment etc. for parts in box 26)? Any special sealant needed to use on gearbox cover or would RTV be good? Thanks
Hi.
Your diagnostics are correct. Unfortunately this spring part #62676 is no longer available. The transmission assembly Part number: 3360629 Good luck. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| upper agitator pops off lower agitator | Olmbre | Washer Repair | 10 | 11-22-2012 07:54 PM |
| Replaced Dog-Ears on Agitator but Top Agitator seems loose | TomAllThumbs | Washer Repair | 3 | 02-14-2011 05:38 PM |
| Agitator Spins Freely on Splined Agitator Shaft | meandme | Washer Repair | 0 | 03-27-2009 08:34 AM |
| Kenmore washer 80 top agitator does not move with bottom agitator | erbaker | Washer Repair | 1 | 02-19-2008 11:11 AM |
| Top agitator on duel agitator not working | bigfoot | Washer Repair | 1 | 10-28-2007 05:34 AM |
