AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Front Loading Washer Won't Go Through Final Spin
My washer runs fine and washes fine until the final spin. The spin cycle starts, but when the timer hits 6 minutes time remaining, the machine cuts off and the cycle end signal sounds. The clothes are still very wet. We have replaced the speed/motor control board per a thread on this site. Same thing. Any suggestions?
Originally Posted by: LisaCWilliams My washer runs fine and washes fine until the final spin. The spin cycle starts, but when the timer hits 6 minutes time remaining, the machine cuts off and the cycle end signal sounds. The clothes are still very wet. We have replaced the speed/motor control board per a thread on this site. Same thing. Any suggestions? The model number is GLTF2940FS2
Originally Posted by: LisaCWilliams The model number is GLTF2940FS2 I have also read that I can do a diagnostic test and if the machines spins in the test, the door latch assembly may be bad. Will the machine spin in diagnotic if the drain pump is bad?
Washer Repair
