spin cycle on empty machine runs very smooth. but with even a 1/2 load in drum bounces an d makes clunking noise, stop machine and redistribute load but same thing. check shocks and springs look ok, but i don't know how to check the shocks, shocks are properly secured.
Operate it with the back off and observe it and see if you can determine what is wrong.
Some times the shocks are bad but the damage is not visible when it is not running.
