Discuss
Wash cycles reduced to "hand wash" only
 in
Washer Repair
I've got a Maytag Neptune washer that only works on the "hand wash" cycle. We get no response when we
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Wash cycles reduced to "hand wash" only
  #1 (permalink)
Old 04-23-2012, 05:54 PM
Junior Member
fixmytag is on a distinguished road
Default Wash cycles reduced to "hand wash" only
Model Number: MAH5500BWW   Brand: Maytag   Age: More than 10 years
I've got a Maytag Neptune washer that only works on the "hand wash" cycle. We get no response when we press the other buttons - no LCD display.
We had a power outage for about 3.5 hours but the washer was off. The next morning when we tried to wash clothes, only the one cycle was available. We unplugged the washer for about 30 seconds, plugged it back in, but no change.
We unplugged it for 5 minutes and we were able to wash as normal with the other cycles available. Two days later, the same thing but having to go through the unplug and wait routine many more times. Now it only works on the "hand wash" cycle.
Do we need a new main circuit board? Not sure if the power outage is just a coincidence for another failure or if a surge damaged the board.
The door switch seems to work - shows a display when open. Anything else that might be causing this?
Thanks very much!
Gary
Ads By Google
Related Models
Maytag MAH5500BWW Washer - Horizontal Axis
Maytag MAH55FLBWQ Washer - Horizontal Axis
Maytag MAH55FLBWW Washer - Horizontal Axis
Maytag MAH6500AWQ Washer - Horizontal Axis
Maytag MAH6500AWW Washer - Horizontal Axis
Maytag MAH6700AWM Washer - Horizontal Axis
Maytag MAH6700AWW Washer - Horizontal Axis
Maytag MAH7500AWQ Washer - Horizontal Axis
Maytag MAH7500AWW Washer - Horizontal Axis
International MAH7550AAW Washer - Horizontal Axis
Maytag MAH7550AGW Washer - Horizontal Axis
International MAH7550AGW Washer - Horizontal Axis
Maytag MAH8700AWM Washer - Horizontal Axis
Maytag MAH8700AWW Washer - Horizontal Axis
Maytag MAH9700AWM Washer - Horizontal Axis
Maytag MAH9700AWQ Washer - Horizontal Axis
Maytag MAH9700AWW Washer - Horizontal Axis
Frigidaire MAL123P1A1 Wwh(v1) / Room Air Conditioner
Maytag MAL1800AXM Misc / Accessory
Maytag MAL1800AXQ Misc / Accessory
Maytag MAL1800AXW Misc / Accessory
Maytag MAL2000AXQ Misc / Accessory
Maytag MAL2000AXW Misc / Accessory
Frigidaire MAS183P2A1 Wwh(v1) / Room Air Conditioner
Maytag MAT10CSAAL Washer - Top Loading
Maytag MAT10CSAAW Washer - Top Loading
Maytag MAT10CSAGL Washer - Top Loading
Maytag MAT10CSAGW Washer - Top Loading
Maytag MAT10CSBKL Washer - Top Loading
Maytag MAT10CSEGL Washer - Top Loading
Maytag MAT10CSEGW Washer - Top Loading
Maytag MAT10DAAAL Washer - Top Loading
Maytag MAT10DAAAW Washer - Top Loading
Maytag MAT10DAABL Washer - Top Loading
Maytag MAT10DAABW Washer - Top Loading
Maytag MAT10PDAAL Washer - Top Loading
Maytag MAT10PDAAW Washer - Top Loading
Maytag MAT10PDABL Washer - Top Loading
Maytag MAT10PDABW Washer - Top Loading
Maytag MAT10PDEGW Washer - Top Loading
Maytag MAT10PSAAL Washer - Top Loading
Maytag MAT10PSAAW Washer - Top Loading
Maytag MAT10PSAGL Washer - Top Loading
Maytag MAT10PSAGW Washer - Top Loading
Maytag MAT11CSBKL Washer - Top Loading
Maytag MAT11MNAAW Washer - Top Loading
Maytag MAT11MNAGW Washer - Top Loading
Maytag MAT11MNEGW Washer - Top Loading
Maytag MAT11PDAAL Washer - Top Loading
Maytag MAT11PDAAW Washer - Top Loading
Maytag MAT11PDABL Washer - Top Loading
Maytag MAT11PDABW Washer - Top Loading
Maytag MAT12CSAAL Washer - Top Loading
Maytag MAT12CSAAQ Washer - Top Loading
Maytag MAT12CSAAW Washer - Top Loading
Maytag MAT12CSAGW Washer - Top Loading
Maytag MAT12CSAKL Washer - Top Loading
Maytag MAT12CSAKQ Washer - Top Loading
Maytag MAT12CSDAQ Washer - Top Loading
Maytag MAT12CSDAW Washer - Top Loading
Maytag MAT12CSDGW Washer - Top Loading
Maytag MAT12CSEGW Washer - Top Loading
Maytag MAT12CSFWQ Washer - Top Loading
Maytag MAT12CSFWW Washer - Top Loading
Maytag MAT12PDAAL Washer - Top Loading
Maytag MAT12PDAAW Washer - Top Loading
Maytag MAT12PDABL Washer - Top Loading
Maytag MAT12PDABW Washer - Top Loading
Maytag MAT12PDAGW Washer - Top Loading
Maytag MAT12PDBAL Washer - Top Loading
Maytag MAT12PDBAQ Washer - Top Loading
Maytag MAT12PDBAW Washer - Top Loading
Maytag MAT12PDBBL Washer - Top Loading
Maytag MAT12PDBBQ Washer - Top Loading
Maytag MAT12PDBBW Washer - Top Loading
Maytag MAT12PDCBL Washer - Top Loading
Maytag MAT12PDCBQ Washer - Top Loading
Maytag MAT12PDCBW Washer - Top Loading
Maytag MAT12PDDAQ Washer - Top Loading
Maytag MAT12PDDAW Washer - Top Loading
Maytag MAT12PDDBW Washer - Top Loading
Maytag MAT12PDDGW Washer - Top Loading
Maytag MAT12PDEGW Washer - Top Loading
Maytag MAT12PDLAQ Washer - Top Loading
Maytag MAT12PDLAW Washer - Top Loading
Maytag MAT12PDLGW Washer - Top Loading
Maytag MAT12PDSAW Washer - Top Loading
Maytag MAT12PRAAW Washer - Top Loading
Maytag MAT12PRAEW Washer - Top Loading
Maytag MAT12PRBAW Washer - Top Loading
Maytag MAT12PRDAW Washer - Top Loading
Maytag MAT12PRSAW Washer - Top Loading
Maytag MAT12PSAAW Washer - Top Loading
Maytag MAT12PSAGW Washer - Top Loading
Maytag MAT12PSBAW Washer - Top Loading
Maytag MAT12PSDAW Washer - Top Loading
Maytag MAT12PSLWQ Washer - Top Loading
Maytag MAT12PSLWW Washer - Top Loading
Maytag MAT13MNAAW Washer - Top Loading
Maytag MAT13MNAGW Washer - Top Loading
Maytag MAT13MNDAW Washer - Top Loading
Maytag MAT13MNDGW Washer - Top Loading
Maytag MAT13MNEGW Washer - Top Loading
Maytag MAT13PDAAW Washer - Top Loading
Maytag MAT13PDBAW Washer - Top Loading
Maytag MAT13PNAEW Washer - Top Loading
Maytag MAT13PNDEW Washer - Top Loading
Maytag MAT13PRBWW Washer - Top Loading
Maytag MAT230CAAG Washer - Top Loading
Maytag MAT23PCAAC Washer - Top Loading
Maytag MAT23PCAAG Washer - Top Loading
Maytag MAT23PCAAL Washer - Top Loading
Maytag MAT23PCAAW Washer - Top Loading
Maytag MAT23PCABG Washer - Top Loading
Maytag MAT23PCABL Washer - Top Loading
Maytag MAT23PCABW Washer - Top Loading
Maytag MAT25CSAAG Washer - Top Loading
Maytag MAT25CSAAL Washer - Top Loading
Maytag MAT25CSAAW Washer - Top Loading
Maytag MAT25CSAGG Washer - Top Loading
  #2 (permalink)
Old 04-24-2012, 04:39 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for Maytag MAH5500BWW WASHER- HORIZONTAL AXIS | AppliancePartsPros.com
Here is a service manual.
http://appliancejunk.com/forums/inde...t=1335 266805
Try running the diagnostics
It does sound like a control board problem.
Page 4-4 of the last manual in the set gives the keypad output.
Since other keys that also use the same pin outputs as the hand wash do not work I doubt it is a keypad problem.
__________________
  #3 (permalink)
Old 04-24-2012, 03:38 PM
Junior Member
Default
Thanks denman for the reply.
When I go to the website you've shown for the service manual, I go to a new forum site that I have to register for and then it automatically sends me to the ************************.com website. However, there are no service manuals available.
Are you sure your website is correct? Is this service manual available as an online reference or do I have to buy it first? I'd like to run the diagnostics before ordering a new board.
Thanks very much.
Gary
  #4 (permalink)
Old 04-25-2012, 02:52 AM
Senior Expert
APP Volunteer
Default
My browser takes me there.
The manual should be free.
Not sure what the problem is.
Try this.
Go to the site and register.
Then go back and log in.
Leave that page open.
Now try my link in a new page/tab.
If that does not work then after logging in go to the site.
the manual is in Service Manuals \ Free Downloads \ Washer Service Repair Manuals \ Page 4 \ 16010061 (last item on the page)
__________________
  #5 (permalink)
Old 05-01-2012, 05:46 PM
Junior Member
Default
Hi Denman;
I talked with you last week about a Maytag Neptune washer that only worked on the hand wash cycle. We installed a new control unit last Friday and it seemed to work OK although when we first installed it, it still displayed the hand wash only cycle light and then seemed to work OK on the other cycles.
Today, it went back to working only on the hand wash cycle.
Any ideas on what could be wrong with it?
Frankly, the service manual is very confusing and we couldn't find the code info on the pages you mentioned.
Any help would be appreciated.
Gary
  #6 (permalink)
Old 05-01-2012, 05:53 PM
Junior Member
PAULBELANGER1960@GMAIL.CO is on a distinguished road
Default
This was no helpo
  #7 (permalink)
Old 05-02-2012, 02:34 AM
Senior Expert
APP Volunteer
Default
You said "it seemed to work OK". Did it run normal or did it run the cycle and still have weird things happening.
The only other thing I can think of is that it is a keypad problem.
Perhaps is the "hand wash" key is always closed it locks out the other keys but I am just guessing here.
Yes they just cover too many unit types.
Yours is the third manual in the set (Supplement five) and even then they also cover yours and a LCD unit.
Page 2-12 of that manual does show that the "hand wash" key is used as an input key during diagnostics so perhaps the unit is being forced into diagnostics.
Page 4-4 of the manual gives the outputs for the keypad.
Other than swapping it out this may be the only way to check it to ensure that each key is open and then closes when pressed.
Diagnostics starts on Page 2-11
The unit logs error/help codes so maybe it is logging in codes and when the log is full locks the unit up, again just a guess.
Try getting into the diagnostics.
Unplug the unit for a few minutes and try it again.
Now does it run OK for a few cycles?
Perhaps it would be helpful to start a new post.
Put in the problem and what you have done so far.
You may get a reply from someone who has actually seen this problem or has more knowledge than I have.
__________________
  #8 (permalink)
Old 05-02-2012, 04:21 PM
Junior Member
Default
Denman;
Thanks for the extensive list of ideas.
I kept trying to get into the diagnostics and it wouldn't do it because it wouldn't go into the Service Mode (press delicates & heavy soil for 3 sec). All I kept getting was the minutes of the cycle - '63. And when I pressed presoak, it just added to the minutes - '78. I played with unplug and plug-in but no change - no access to service mode. Each time though when I plugged it back in, the hand wash light and a few others were on and no way to change.
I unplugged the machine again and went and read more from section 2 and decided to do the membrane pad check. Again, no luck with getting into the service mode, but I just started pressing all the different keys and suddenly I was able to turn on the cotton/sturdy, wrinkle free, delicates cycle button (wouldn't come on before). I turned the machine off and tried it again, seemed OK. Did it again, this time pressing the hand wash and then pressing others - all OK! Not sure what happened but it may be as you say, the keypad sticking but we'll use it for now. My guess is we'll need a new keypad sometime in the future.
Thanks for all the tips. If you think I should do anything else, please let me know.
Gary
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Flashing "Normal Wash" light. Will not Run/Reset/NADA! socaldave Dishwasher Repair 8 09-02-2011 03:30 AM
Washer making a "Thunk-Squeek" sound during wash cycle.... Pugsly Washer Repair 3 07-19-2011 03:48 PM
Will only do final spin in "quick wash" citti34 Washer Repair 2 08-19-2010 05:23 PM
GE Washing machine making a "Thunking" noise in wash cycle Flogger Washer Repair 0 05-28-2010 09:15 AM
Works on "rinse only" but stops on "wash". Bill E Dishwasher Repair 5 05-27-2009 03:00 AM
