Register | FAQ's | New Posts | Today's Posts | Extras |
» Maytag washer will not agitate or spin |
![]() Model Number: LAT9406AAE Brand: Maytag Age: 5 - 10 years
![]() Maytag washer quit spinning or agitating this morning. The motor will "hum" when either are engaged. So I took the front panel off and drained the water and removed the cloths. When I now engage the spin cycle the basket will begin to spin for about 5 secs. A click can be heard (sounds like a breaker) and the unit will cut off. There is a slight smell of rubber/electrical that follows. After a minute or so you hear another click and the process can be repeated if wanted. I appreciate any advice. Thank you. Related Models Last edited by roscoepcoltrain : 04-19-2012 at 07:25 AM. |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Hi,
See if you can turn the pump pulley easily by hand. Maybe something is stuck in the pump.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum |
![]() Both belts move easily in both directions. Do not know if it should or not but motor pulley will not turn by hand. With spin cycle engaged, motor hums, after a few seconds "breaker" kicks motor off, I see a small amount of smoke off top of motor. If left on it will reset itself after maybe a minute and repeat. Is the motor seized up by chance? Thanks!
![]() Gave it another look. I took the pump belt off so I could get my hands on the motor pulley easier. It was pretty stiff at first but began to turn freely after a few tries. I put the washer in the spin cycle empty and it worked fine. I then put it into a small wash cycle w/o cloths, fine again. So added the cloths back from earlier & put it on a large load and let it go. It has now made its way to the spin cycle with no issue. So, I have no idea if I have an issue on the horizon or what??? But right now it is working.
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Maytag Washer will not agitate or spin | Mbat4 | Washer Repair | 1 | 02-15-2012 12:56 PM |
Maytag Washer Won't Spin or Agitate | scott805 | Washer Repair | 8 | 11-19-2010 09:53 AM |
Maytag Washer does not agitate or spin | myvelasquez | Washer Repair | 5 | 01-10-2010 07:28 PM |
Maytag washer won't fill or agitate, but will spin | spitz72 | Washer Repair | 1 | 11-26-2009 07:35 AM |
Maytag Washer will not agitate but will spin and rinse | pkbeckman | Washer Repair | 3 | 02-24-2009 02:36 PM |
