The washing machine no longer spins balanced with a heavy load. It appears that the shocks might be going. How do I tell which if any of the shocks are bad? Do all 4 typically need to be replaced at the same time?
Groups: APP Team
Hi.
The model number you provided doesn't come up in the research, please check and post. But in general if you are not able to see any obvious greasy spots on the shocks and nothing is broken they still might be weak. With the model number I'll get you more detailed instructions.
Thank you.
Simon.
