Discuss
white Westinghouse stack unit excessive belt slip
 in
Washer Repair
Bought unit used had bad belt replaced belt and pulley on trans when unit goes into spin belt slips and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » white Westinghouse stack unit excessive belt slip
  #1 (permalink)
Old 04-18-2012, 05:51 PM
Junior Member
wvopowered is on a distinguished road
Default white Westinghouse stack unit excessive belt slip
Model Number: mlxe62rbw2   Brand: White-Westinghouse   Age: More than 10 years
Bought unit used had bad belt replaced belt and pulley on trans when unit goes into spin belt slips and you get a burning rubber smell. looks like there is a adjustment or actualy feels like for the spring on the idler should that be tighter may be?if so how do you change it can it be done with out pulling the drum out. Belt is correct factory belt made to slip but watching it it takes a long time to get up to speed and is better when hot as in after it has run thur one spin cycle then you put it thru another it seems a little better. I saw one coment about the drum bearings being tight and causing this also . any info appreciated.
Ads By Google
Related Models
Frigidaire MLXE62RBW2 Frg(v2) / Laundry Center
Frigidaire MLXE62RBW3 Frg(v2) / Laundry Center
Frigidaire MLXE62RBWD0 Kel(v10) / 27 " Electric Laundry Center
Frigidaire MLXE62RBWL0 Frg(v2) / 27 " Electric Laundry Center
Frigidaire MLXE62RBWW0 Frg(v1) / 27 " Electric Laundry Center
Frigidaire MLXE62RED0 Frg(v1) / Laundry Center
Frigidaire MLXE62RED3 Frg(v1) / Laundry Center
Frigidaire MLXE62REW0 Frg(v2) / Laundry Center
Frigidaire MLXE62REW1 Frg(v0) / Laundry Center
Frigidaire MLXE62REW2 Frg(v0) / Laundry Center
Frigidaire MLXE62REW3 Frg(v2) / Laundry Center
Frigidaire MLXG42RBD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MLXG42RBD1 Gib(v1) / 27 " Gas Laundry Center
Frigidaire MLXG42RBD2 Frg(v1) / Laundry Center
Frigidaire MLXG42RBD3 Frg(v1) / Laundry Center
Frigidaire MLXG42RBW0 Tap(v4) / 27 " Gas Laundry Center
Frigidaire MLXG42RBW1 Gib(v2) / 27 " Gas Laundry Center
Frigidaire MLXG42RBW2 Frg(v2) / Laundry Center
Frigidaire MLXG42RBW3 Frg(v2) / Laundry Center
Frigidaire MLXG42RBWD0 Kel(v10) / 27 " Gas Laundry Center
Frigidaire MLXG42RBWL0 Frg(v2) / 27 " Gas Laundry Center
Frigidaire MLXG42RBWW0 Frg(v1) / 27 " Gas Laundry Center
Frigidaire MLXG42RED0 Frg(v1) / Laundry Center
Frigidaire MLXG42RED2 Frg(v1) / Laundry Center
Frigidaire MLXG42RED3 Frg(v1) / Laundry Center
Frigidaire MLXG42RED4 Frg(v1) / Laundry Center
Frigidaire MLXG42REW0 Frg(v2) / Laundry Center
Frigidaire MLXG42REW1 Frg(v0) / Laundry Center
Frigidaire MLXG42REW2 Frg(v2) / Laundry Center
Frigidaire MLXG42REW3 Frg(v2) / Laundry Center
Frigidaire MLXG42REW4 Frg(v2) / Laundry Center
Frigidaire MLXG62RBD0 Wwh(v4) / 27 " Gas Laundry Center
Frigidaire MLXG62RBD1 Frg(v1) / 27 " Gas Laundry Center
Frigidaire MLXG62RBD2 Frg(v1) / Laundry Center
Frigidaire MLXG62RBD3 Frg(v1) / Laundry Center
Frigidaire MLXG62RBL0 Frg(v2) / 27 " Gas Laundry Center
Frigidaire MLXG62RBW0 Tap(v4) / 27 " Gas Laundry Center
Frigidaire MLXG62RBW1 Frg(v2) / 27 " Gas Laundry Center
Frigidaire MLXG62RBW2 Frg(v2) / Laundry Center
Frigidaire MLXG62RBW3 Frg(v2) / Laundry Center
Frigidaire MLXG62RED0 Frg(v1) / Laundry Center
Frigidaire MLXG62REW0 Frg(v2) / Laundry Center
Frigidaire MLXG62REW1 Frg(v0) / Laundry Center
Maytag MLY1645ADB Rv Range - Gas
Maytag MLY1645ADH Rv Range - Gas
Maytag MLY2245ADB Rv Range - Gas
Maytag MLY2245ADH Rv Range - Gas
Maytag MLY2256ADB Rv Range - Gas
Maytag MLZ8505ADB Rv Surface Unit - Gas
Maytag MLZ8505ADH Rv Surface Unit - Gas
Amana MM2000C Commercial Microwaves
Menu Master MM2000C  Commercial Microwaves
Amana MM2000CS Commercial Microwaves
Amana MM2230C Commercial Microwaves
Amana MM2230CS Commercial Microwaves
Amana MM659E Mwave - Cntrtp / Stand Alone
Amana MM659W Mwave - Cntrtp / Stand Alone
Maytag MMA27B Misc / Accessory
Maytag MMA27Q Misc / Accessory
Maytag MMA27W Misc / Accessory
Maytag MMA30B Misc / Accessory
Maytag MMA30Q Misc / Accessory
Maytag MMA30W Misc / Accessory
Bosch MMB9110 UC/03 (FD 8110 -)
International MMC1500CGE Ref - Top Mount
Maytag MMC5000ADB Mwave - Mounted Under Cabinet
Maytag MMC5000ADW Mwave - Mounted Under Cabinet
Maytag MMC5000BDB Mwave - Mounted Under Cabinet
Maytag MMC5000BDQ Mwave - Mounted Under Cabinet
Maytag MMC5000BDW Mwave - Mounted Under Cabinet
Maytag MMC5080AAB Mwave - Cntrtp / Stand Alone
Maytag MMC5080AAS Mwave - Cntrtp / Stand Alone
Maytag MMC5080AAW Mwave - Cntrtp / Stand Alone
Maytag MMC5086AAB Mwave - Cntrtp / Stand Alone
Maytag MMC5086AAQ Mwave - Cntrtp / Stand Alone
Maytag MMC5086AAS Mwave - Cntrtp / Stand Alone
Maytag MMC5086AAW Mwave - Cntrtp / Stand Alone
Maytag MMC5193AAB Mwave - Cntrtp / Stand Alone
Maytag MMC5193AAQ Mwave - Cntrtp / Stand Alone
Maytag MMC5193AAS Mwave - Cntrtp / Stand Alone
Maytag MMC5193AAW Mwave - Cntrtp / Stand Alone
International MMD1700CGE Ref - Top Mount
Whirlpool MME08XW0
Whirlpool MME08XW1
Amana MMO166 Mwave - Mounted Over Range/wo
Amana MMO166/101W Mwave - Family Size (60 Hz)
Amana MMO16610 Mwave - Family Size (60 Hz)
Amana MMO166MN002 Range - S/c S/i Ddraft Gas
Amana MMO219 Mwave - Cntrtp / Stand Alone
Amana MMO2661D Mwave - Mounted Over Range/wo
Amana MMO2661W Mwave - Mounted Over Range/wo
Amana MMO2671D01 Mwave - Family Size (60 Hz)
Amana MMO2671WW01 Mwave - Family Size (60 Hz)
Maytag MMV1153AAB Mwave - Mounted Over Range/wo
Maytag MMV1153AAW Mwave - Mounted Over Range/wo
Maytag MMV1153BAB Mwave - Mounted Over Range/wo
Maytag MMV1153BAQ Mwave - Mounted Over Range/wo
Maytag MMV1153BAS Mwave - Mounted Over Range/wo
Maytag MMV1153BAW Mwave - Mounted Over Range/wo
Maytag MMV4184AAB Mwave - Mounted Under Cabinet
Maytag MMV4184AAQ Mwave - Mounted Under Cabinet
Maytag MMV4184AAW Mwave - Mounted Under Cabinet
Maytag MMV4205AAB Mwave - Mounted Over Range/wo
Maytag MMV4205AAQ Mwave - Mounted Over Range/wo
Maytag MMV4205AAS Mwave - Mounted Over Range/wo
Maytag MMV4205AAW Mwave - Mounted Over Range/wo
Maytag MMV4205BAB Mwave - Mounted Over Range/wo
Maytag MMV4205BAQ Mwave - Mounted Over Range/wo
Maytag MMV4205BAS Mwave - Mounted Over Range/wo
Maytag MMV4205BAW Mwave - Mounted Over Range/wo
Maytag MMV5000ADA Mwave - Mounted Under Cabinet
Maytag MMV5000ADB Mwave - Mounted Under Cabinet
Maytag MMV5000ADW Mwave - Mounted Under Cabinet
Maytag MMV5000BAB Mwave - Mounted Under Cabinet
Maytag MMV5000BAC Mwave - Mounted Under Cabinet
Maytag MMV5000BAQ Mwave - Mounted Under Cabinet
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
White Westinghouse JohnWoods Dishwasher Repair 0 06-16-2011 04:49 PM
white westinghouse washer belt replacement Kmcduffie Washer Repair 8 05-27-2011 02:41 PM
White Westinghouse appliance co. Dean Andrews Dryer Repair 1 03-30-2011 04:12 PM
White WestingHouse Gr8ful Dryer Repair 1 03-13-2010 01:51 AM
white-westinghouse dishwasher. mommieof2 Dishwasher Repair 1 09-19-2007 06:10 PM
