My washer overflowed and flooded my garage. I had washed blanket and may have been to heavy, although I have done this before. Water was pouring out the top of the washer and from underneath. It would not spin or drain. I un plugged the machine, shut the water off. I took the wet blanket out. I plugged the machine in again and put the water back on. I set the dial to spin and it did spin and the water emptied and was still leaking from underneath. I turned the dial to wash and it would not agitate. I did replace the coupler about 6 months ago when it would not spin or agitate. It appears the agitator is not working but if that is bad would it still leak from underneath
Groups: APP Team
Hi.
You may have stripped agitator splines or it's a bad transmission. On the top of it - the water leak is not related to the agitator problem. Tough decision.
Post the results if you need any help.
Simon.
