Discuss
Washer won't agitate, drain, or spin
 in
Washer Repair
Please help, this is my 4th washer! Kenmore series 70 will fill, then will not agitate (makes clcking noise. Cannot
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer won't agitate, drain, or spin
  #1 (permalink)
Old 04-18-2012, 06:57 AM
Junior Member
kaghjeff64 is on a distinguished road
Default Washer won't agitate, drain, or spin
Model Number: 20712-990   Brand: Kenmore   Age: 5 - 10 years
Please help, this is my 4th washer! Kenmore series 70 will fill, then will not agitate (makes clcking noise. Cannot turn agitator by hand even. It also will not drain or spin, all the while still making this clicking noise. What should I check? Thanks!
Related Models
Amana 2072.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2072.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2074.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2075B0A Ranges, Electric*
Roper 2075B1A Ranges, Electric*
Roper 2075B2A Ranges, Electric*
Amana 2085.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2085.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2089.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 2090.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 2091.004 MWAVE - FAMILY SIZE (60 HZ)
Amana 2092.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2092B0A Ranges, Electric*
Roper 2092B1A Ranges, Electric*
Roper 2092B2A Ranges, Electric*
Roper 2092B3A Ranges, Electric*
Amana 2094.004 MWAVE - FAMILY SIZE (60 HZ)
Roper 2095B0A Ranges, Electric*
Roper 2095B1A Ranges, Electric*
Roper 2095B2A Ranges, Electric*
Amana 210-3B ROOM AIR CONDITIONER
Hoover 2100
Roper 2101*0E Ranges, Electric*
Roper 2101*1E Ranges, Electric*
Roper 2101*2E Ranges, Electric*
Amana 21011 COMMERCIAL MICROWAVES
Amana 21016 COMMERCIAL MICROWAVES
Roper 2101W0E Ranges, Electric*
Roper 2101W1E Ranges, Electric*
Roper 2101W2E Ranges, Electric*
Roper 2102*0E Ranges, Electric*
Roper 2102*1E Ranges, Electric*
Roper 2102*2E Ranges, Electric*
Roper 2102W0E Ranges, Electric*
Roper 2102W1E Ranges, Electric*
Roper 2102W2E Ranges, Electric*
Amana 210W-3B ROOM AIR CONDITIONER
Amana 210W-3BH ROOM AIR CONDITIONER
Amana 210W-3J ROOM AIR CONDITIONER
Amana 210W-3JH ROOM AIR CONDITIONER
Amana 210W-3SP ROOM AIR CONDITIONER
Amana 210W-3SPF ROOM AIR CONDITIONER
Amana 210W-3SPFH ROOM AIR CONDITIONER
Amana 210W-3SPG ROOM AIR CONDITIONER
Amana 210W-3SPGH ROOM AIR CONDITIONER
Amana 210W-3SPH ROOM AIR CONDITIONER
Hoover 2110
Jenn-Air 21136 WALLOVEN- S/C ELE
Jenn-Air 21137 WALLOVEN- S/C ELE
Jenn-Air 21138 ELECTRIC WALL OVEN
Amana 212-2J ROOM AIR CONDITIONER
Amana 212-2J-1 ROOM AIR CONDITIONER
Amana 212-2JM ROOM AIR CONDITIONER
Amana 212-2SP ROOM AIR CONDITIONER
Amana 212-2SPF ROOM AIR CONDITIONER
Amana 212-2SPG ROOM AIR CONDITIONER
Amana 212-3J ROOM AIR CONDITIONER
Amana 212-3J-1 ROOM AIR CONDITIONER
Amana 212-3SP ROOM AIR CONDITIONER
Amana 212-3SPG ROOM AIR CONDITIONER
Hoover 2120
Hoover 2120-01
Jenn-Air 21238 WALLOVEN- S/C ELE
Jenn-Air 21239 WALLOVEN- S/C ELE
Roper 2126*0A Ranges, Electric*
Roper 2126X0A Ranges, Electric*
Frigidaire 2129A GAS RANGE
Frigidaire 2129B GAS RANGE
Frigidaire 2129C GAS RANGE
Amana 212D-3J ROOM AIR CONDITIONER
Amana 212D-3JH ROOM AIR CONDITIONER
Amana 212D-3JM ROOM AIR CONDITIONER
Amana 213-3B ROOM AIR CONDITIONER
Amana 213-3BH ROOM AIR CONDITIONER
Amana 213-3E ROOM AIR CONDITIONER
Amana 213-3F ROOM AIR CONDITIONER
Amana 213-3G ROOM AIR CONDITIONER
Amana 213-5B ROOM AIR CONDITIONER
Amana 213-5BH ROOM AIR CONDITIONER
Amana 213-5J ROOM AIR CONDITIONER
Amana 213-5JH ROOM AIR CONDITIONER
Amana 213-5SP ROOM AIR CONDITIONER
Amana 213-5SPF ROOM AIR CONDITIONER
Amana 213-5SPFH ROOM AIR CONDITIONER
Amana 213-5SPG ROOM AIR CONDITIONER
Amana 213-5SPGH ROOM AIR CONDITIONER
Amana 213-5SPH ROOM AIR CONDITIONER
Jenn-Air 21336 WALLOVEN- S/C MWAVE ELE
Roper 2136*0A Ranges, Electric*
Roper 2136X0A Ranges, Electric*
Amana 213D-3C ROOM AIR CONDITIONER
Amana 213D-3CH ROOM AIR CONDITIONER
Roper 2141*0E Ranges, Electric*
Roper 2141*1E Ranges, Electric*
Roper 2141W0E Ranges, Electric*
Roper 2141W1E Ranges, Electric*
Roper 2142*0E Ranges, Electric*
Roper 2142*1E Ranges, Electric*
Roper 2142W0E Ranges, Electric*
Roper 2142W1E Ranges, Electric*
Roper 2143*0F Ranges, Electric*
Roper 2143W0F Ranges, Electric*
Roper 2144*0F Ranges, Electric*
Roper 2144W0E Ranges, Electric*
  #2 (permalink)
Old 04-18-2012, 12:47 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
Please provide the correct model number.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-21-2012, 07:02 AM
Junior Member
Default
Quote:
Originally Posted by Simon / APP Team View Post
Hi.
Simon.
The model # is110 20712 990. Last load was heavy duty agitate mode. Chinking sound now. No agitate, drain or spin. Thanks for your reply. Must go drop $20 at laundrmat now.
  #4 (permalink)
Old 04-21-2012, 07:03 AM
Junior Member
Default Machine repair help.
Hi.
Simon.
  #5 (permalink)
Old 04-21-2012, 07:08 AM
Junior Member
Default P.S.
Also, cannot turn agitator by hand, locked up. But would that effect draining? Its weird.
  #6 (permalink)
Old 04-23-2012, 11:27 AM
Expert
Default
Hi.
To get to the pump,motor and transmission you need to remove the cabinet.
Unplug the unit.
Pry off the end caps, remove two screws and lift the control panel.
Remove two clips (one on each side), disconnect the lid switch plug.
Remove the cabinet.
Remove the drain pump of the motor shaft and start the washer (in agitate).
If the pump is bad - replace it.
The drain pump Part number: 3363394
Thank you.Post the results.
Simon.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not agitate, spin or drain Paul921 Washer Repair 5 01-23-2012 04:11 PM
Washer Won't Drain Spin Or Agitate carlous Washer Repair 15 10-08-2011 08:31 PM
Washer won't agitate, spin, drain terriahome Washer Repair 5 09-28-2010 09:33 AM
washer won't spin but will agitate and drain mndoughboy Washer Repair 0 07-03-2010 01:41 PM
Washer does not agitate, spin or drain nun4joy Washer Repair 4 05-03-2010 12:28 PM
