| » Burnt Rubber Smell |
Model Number: ALW480DAW Brand: Amana Age: 5 - 10 years
Have an Amana top load washer, approx. 7 yrs. old. Recentlly I replaced the belt after it shredded, the pump (because I had to cut it off), and the motor (I damaged the pulley trying to get the pump off). The unit seemed to run fine for about 3 weeks, untol the belt broke again. I replaced the belt, but noticed belt dust on the pulley as I was testing the unit. I also noticed on the final spin cycle that the unit seemed alittle louder than normal. What could it be? Could it be the transmission? Where should I start looking?
| Display Modes | |
| White Westinghouse Washer won't drain and has burnt rubber smell | brandiannh | Washer Repair | 1 | 11-27-2009 10:41 AM |
| Will not spin, burnt rubber smell? | Gerry O | Washer Repair | 2 | 10-19-2009 11:33 AM |
| No spin burnt rubber smell screeching sound | tinkerman745 | Washer Repair | 5 | 09-15-2009 01:41 AM |
| Whirlpool makes grinding noise, won't spin, smelled burnt rubber | Ruth D. | Washer Repair | 0 | 02-01-2009 08:10 AM |
| Burnt Rubber Smell & Smoke | hchatton | Washer Repair | 1 | 10-24-2008 03:33 PM |
