Discuss
Door lock or something else?
 in
Washer Repair
Washer will not spin.I checked the pump and hose, washer drains fine. On the door lock the solenoid locks the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Door lock or something else?
  #1 (permalink)
Old 04-16-2012, 12:58 PM
Junior Member
Jeffrobodeen is on a distinguished road
Default Door lock or something else?
Model Number: GLTR1670ASO   Brand: Frigidaire   Age: 1 - 5 years
Washer will not spin.I checked the pump and hose, washer drains fine. On the door lock the solenoid locks the door and the spin light comes on when you shut the door. What does the coil in the door lock do and is there a way to test it? Or is my problem something else?
Ads By Google
Related Models
Whirlpool GLWA6900W0
Whirlpool GLWA6900W1
Whirlpool GLWA6900W2
Frigidaire GLWS1233AQ1 Washer - Frig Gallery
Frigidaire GLWS1233AQ2 Frigidaire/washer
Frigidaire GLWS1233AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1233AS1 Washer - Gallery
Frigidaire GLWS1233AS2 Frigidaire/washer
Frigidaire GLWS1233AS3 Frigidaire/washer
Frigidaire GLWS1339CC0 Frigidaire/washer
Frigidaire GLWS1339CS0 Frigidaire/washer
Frigidaire GLWS1339CS1 Frigidaire/washer
Frigidaire GLWS1339EC0 Frigidaire/washer
Frigidaire GLWS1339EC1 Frigidaire/washer
Frigidaire GLWS1339ES0 Frigidaire/washer
Frigidaire GLWS1339ES1 Frigidaire/washer
Frigidaire GLWS1349AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1349AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS0 Washer - Frig Gallery
Frigidaire GLWS1649AS1 Washer - Frig Gallery
Frigidaire GLWS1649AS2 Frigidaire/washer
Frigidaire GLWS1649AS4 Frigidaire/washer
Frigidaire GLWS1749AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1749AS2 Washer - Frig Gallery
Frigidaire GLWS1749AS4 Frigidaire/washer
Frigidaire GLWS1749AS5 Frigidaire/washer
Frigidaire GLWS1939AS0 Frigidaire/washer
Frigidaire GLWS1939AS1 Frigidaire/washer
Frigidaire GLWS1979AS0 Washer - Frigidaire Gallery
Frigidaire GLWS1979AS2 Washer - Frig Gallery
Frigidaire GLWS1979AS3 Frigidaire/washer
Frigidaire GLWY1343AS0 Frigidaire/washer
Frigidaire GLWY1343AS1 Frigidaire/washer
Whirlpool GLXA6900W0
Whirlpool GLXA6900W1
Whirlpool GLXA6900W2
Whirlpool GLXA6900W3
Gaggenau GM104-710
Gaggenau GM104-714
International GM1110PRW Range - F/s Std Gas
Gaggenau GM215-721
Gaggenau GM215-760
Gaggenau GM215-761
Gaggenau GM286-710
Gaggenau GM286-720
Gaggenau GM286-760
Gaggenau GM288-710
Gaggenau GM288-714
International GM3110MPAW Range - F/s Std Gas
International GM3110MXAW Range - F/s Std Gas
International GM3110PRAM Range - F/s Std Gas
International GM3110PRWM Range - F/s Std Gas
International GM31113WAM Range - F/s Std Gas
International GM31113WAV Range - F/s Std Gas
International GM3111GXAW Range - F/s Std Gas
International GM3111SXAW Range - F/s Std Gas
International GM31211XAW Range - F/s Std Gas
International GM3167WUA Range - F/s Std Gas
International GM3167WUV Range - F/s Std Gas
International GM3210MXAW Range - F/s Cont Clean Gas
International GM3211GXAA Range - F/s Cont Clean Gas
International GM3211GXAW Range - F/s Cont Clean Gas
International GM3211SXAA Range - F/s Cont Clean Gas
International GM3211SXAW Range - F/s Cont Clean Gas
International GM3216WRWM Range - F/s Cont Clean Gas
International GM32211XAW Range - F/s Cont Clean Gas
International GM3267WUAM Range - F/s Cont Clean Gas
International GM3267WUWM Range - F/s Cont Clean Gas
International GM3267XUA Range - F/s Cont Clean Gas
International GM3267XUAM Range - F/s Cont Clean Gas
International GM3267XUW Range - F/s Cont Clean Gas
International GM3267XUWM Range - F/s Cont Clean Gas
Gaggenau GM335-760
Maytag GM3468XUW-X Range - S/c F/s Gas
Maytag GM3468XUWX Range - S/c F/s Gas
International GM3510PRW Range - F/s Std Ele
International GM3531WUV Range - S/c F/s Ele
International GM3531WUW Range - S/c F/s Ele
International GM3631XUA Range - F/s Std Ele
International GM3631XUW Range - F/s Std Ele
International GM3862XUW Range - S/c F/s Ele
International GM3868XUA Range - S/c F/s Ele
International GM3868XUW Range - S/c F/s Ele
Maytag GM4151WTA Range - F/s Std Gas
Maytag GM4151WTW Range - F/s Std Gas
Maytag GM4251WTA Range - F/s Cont Clean Gas
Maytag GM4251WTW Range - F/s Cont Clean Gas
Whirlpool GM8131XEB0
Whirlpool GM8131XEB1
Whirlpool GM8131XEQ0
Whirlpool GM8131XEQ1
Whirlpool GM8155XJB0
Whirlpool GM8155XJB1 Convection Microwave Oven
Whirlpool GM8155XJB2 Convection Microwave Oven
Whirlpool GM8155XJQ0
Whirlpool GM8155XJQ1 Convection Microwave Oven
Whirlpool GM8155XJQ2 Convection Microwave Oven
Whirlpool GM8155XJT0
Whirlpool GM8155XJT1 Convection Microwave Oven
Whirlpool GM8155XJT2 Convection Microwave Oven
Gaggenau GM915-710 UC/06 (FD 7710-7912)
Gaggenau GM915-710 UC/11 (FD 7912-8003)
Gaggenau GM915-710 UC/12 (FD 8003-)
Gaggenau GM926-710 UC/06 (FD 7710-7912)
Gaggenau GM926-710 UC/11 (FD 7912-8003)
Gaggenau GM926-710 UC/12 (FD 8003-)
Whirlpool GMA
Whirlpool GMC275PDB0
Whirlpool GMC275PDB07 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDB08 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDB1
Whirlpool GMC275PDB2
Whirlpool GMC275PDB3
Whirlpool GMC275PDB4
Whirlpool GMC275PDB5
Whirlpool GMC275PDB6
Whirlpool GMC275PDQ0
Whirlpool GMC275PDQ07 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDQ08 27" Built - in Electric Combo Sensor/sc (gold Line)
Whirlpool GMC275PDQ1
  #2 (permalink)
Old 04-16-2012, 02:56 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
It's a bit tricky. The door luck failure is very common problem.
The wax motor (the brown part on the side of the switch) in ideal world should be 1500 Ohms. If it measures 2% less - the recommendation is to replace it.
Check all the connections at the timer and motor control board down at the bottom.
The door luck assembly Part number: 131763202
Good luck. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 04-19-2012, 06:26 PM
Junior Member
Default
My was motor on the door lock ohms out at 1765 ohms. You said it should be 1500 and if 2% less should be replaced. What about the higher ohm reading I got?
  #4 (permalink)
Old 04-19-2012, 06:32 PM
Expert
Default
Hi.
Replace the door lock.
Post the results.
Simon.
__________________
  #5 (permalink)
Junior Member
Default
Also on the door lock coil, it ohms at 1320. Is this too much?
  #6 (permalink)
Old 04-19-2012, 06:41 PM
Junior Member
Default
I also tried to open the door when locked. It would not open but I could hear the wax motor clicking and buzzing! I don't quite understand the wax motor, but sounds like I will replace it! Is this a returnable part? The washer will agitate and drain, just won't spin!
  #7 (permalink)
Old 04-22-2012, 05:24 AM
Junior Member
Default
I received the new door lock assembly on Saturday. That was the problem, washer spins like it should now! Thanks for the help!
  #8 (permalink)
Old 04-23-2012, 11:47 AM
Expert
Default
You are very welcome.
Simon.,
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave Oven door lock does not lock thr door Irving Microwave Repair 0 04-11-2012 08:59 PM
door forced open, now door wont lock, drain runs steady scot123 Washer Repair 1 12-20-2011 05:59 PM
oven door lock loose/ "lock' Flashing Tiaya Oven Repair (including Ranges and Cooktops) 0 04-02-2011 10:46 PM
Showing Door Lock is Failing to Lock Ruby123 Washer Repair 1 01-06-2011 07:13 PM
F9 code Oven turns off,lock light turns on,door does not lock darling132 Oven Repair (including Ranges and Cooktops) 1 11-12-2008 02:06 PM
