washer was running then something happened and it quit draining the agitater will still work, i checked the drain pump no clog and the lid switch is working,timer is working any ideas...thanks
Groups: APP Team
Hi.
Please provide the complete model number.
Simon.
Groups: APP Team
Hi.
Does the washer stops full of water where it suppose to drain and spin on any cycles? How did you decide that the lid switch is OK?
Simon.
yes it stopped at the time to drain...the lid switch i read on this forum if it clicks the switch is good..do you think its the switch?
Groups: APP Team
Hi. There is the way to check the lid switch. Unplug the washer, snap off end caps, remove one screw on each side and open the control panel. Locate 3 wire plug going through the panel and install the jumper between 2 outside wires. Plug the washer in and start it. If the washer starts - replace the lid switch. The lid switch Part number: 285671
Good luck. Post the results. Simon.
