Appliance Repair Forum
-   Washer Repair (http://forum.appliancepartspros.com/washer-repair/)
-   -   Agitator popping up (http://forum.appliancepartspros.com/washer-repair/467470-agitator-popping-up.html)
BISKER82 04-15-2012 07:36 PM
Agitator popping up
Our agitator on our admiral washing machine, model #LCN6764A71, keeps popping up during the wash cycle. We replaced the upper agitator, AP4024469, but that did not solve the problem. If we also replace the agitator base will that fix it?
denman 04-16-2012 06:48 AM
Replacement parts for Admiral LNC6764A71 WASHER-TOP LOADING | AppliancePartsPros.com
Have you checked the screw (Item 4 in Section 10).
If you click on the part's picture a new page will open with a Q&A section about it.
If the upper agitator is what is coming loose then I would assume that it is the bottom section that needs replacing but cannot guarantee this without actually being there.
