Discuss
Washer only fills with 4-5" of water, then runs
 in
Washer Repair
Whirlpool clothes washer works fine, except when filling for both wash and rinse cycles, it will only fill to approx
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer only fills with 4-5" of water, then runs
  #1 (permalink)
Old 04-15-2012, 06:57 PM
Junior Member
KKRRSS is on a distinguished road
Default Washer only fills with 4-5" of water, then runs
Model Number: LBR5232EQ1   Brand: Whirlpool   Age: 5 - 10 years
Whirlpool clothes washer works fine, except when filling for both wash and rinse cycles, it will only fill to approx the low level. The dial is set to high.
It will finish the cycle this way, it's just not cleaning the clothes properly.
I can add water with a hose and it will clean properly.
Is this the switch on the top of the unit or something else?
Thank you for any help,
KRS
Related Models
Whirlpool LBR5232EQ1
Whirlpool LBR5232EQ2 AUTOMATIC WASHER
Whirlpool LBR5232EZ0
Whirlpool LBR5232EZ1
Whirlpool LBR5232EZ2 AUTOMATIC WASHER
Whirlpool LBR5432JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LBR5432JQ1 WASHER
Whirlpool LBR5432JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LBR5432JT1 WASHER
Whirlpool LBR5432LQ0 WASHER - DIRECT DRIVE
Whirlpool LBR5432LQ1 AUTOMATIC WASHER
Whirlpool LBR5432PQ0 AUTOMATIC WASHER
Whirlpool LBR5432PQ1 AUTOMATIC WASHER
Whirlpool LBR5432PQ2 AUTOMATIC WASHER
Whirlpool LBR5432PT0 AUTOMATIC WASHER
Whirlpool LBR5432PT1 AUTOMATIC WASHER
Whirlpool LBR5432PT2 AUTOMATIC WASHER
Whirlpool LBR6133DQ0
Whirlpool LBR6133DZ0
Whirlpool LBR6233AG0
Whirlpool LBR6233AN0
Whirlpool LBR6233AW0
Whirlpool LBR6233AW1
Whirlpool LBR6233DQ0
Whirlpool LBT6133AG0
Whirlpool LBT6133AN0
Whirlpool LBT6133AW0
Whirlpool LBT6133AW1
Whirlpool LBT6233DQ0
Whirlpool LBV5133AG0
Whirlpool LBV5133AN0
Whirlpool LBV5133AW0
Amana LC-10.000 COMMERCIAL MICROWAVES
Amana LC-10VP.000 COMMERCIAL MICROWAVES
Amana LC-14.000 COMMERCIAL MICROWAVES
Amana LC-14.001 COMMERCIAL MICROWAVES
Amana LC-14VP.000 COMMERCIAL MICROWAVES
Amana LC10EVP.000 COMMERCIAL MICROWAVES
Frigidaire LC120DH5 Frg(v2) / Laundry Center
Frigidaire LC120DL5 Frg(v3) / Laundry Center
Frigidaire LC120DW5 Frg(v1) / Laundry Center
Frigidaire LC120FH1 Frg(v3) / Laundry Center
Frigidaire LC120FL0 Frg(v2) / Laundry Center
Frigidaire LC120FL1 Frg(v2) / Laundry Center
Frigidaire LC120FW0 Frg(v1) / Laundry Center
Frigidaire LC120FW1 Frg(v1) / Laundry Center
Frigidaire LC120JL5 Frg(v1) / Laundry Center
Frigidaire LC120JW5 Frg(v2) / Laundry Center
Amana LC14EVP.000 COMMERCIAL MICROWAVES
Frigidaire LC248DH5 Frg(v2) / Laundry Center
Frigidaire LC248DL5 Frg(v3) / Laundry Center
Frigidaire LC248DW5 Frg(v1) / Laundry Center
Frigidaire LC248EH0 Frg(v2) / Laundry Center
Frigidaire LC248EL0 Frg(v3) / Laundry Center
Frigidaire LC248EW0 Frg(v1) / Laundry Center
Frigidaire LC248FL0 Frg(v2) / Laundry Center
Frigidaire LC248FW0 Frg(v1) / Laundry Center
Frigidaire LC248H1 Frg(v2) / Laundry Center
Frigidaire LC248JL6 Frg(v3) / Laundry Center
Frigidaire LC248JW6 Frg(v4) / Laundry Center
Frigidaire LC248L1 Frg(v3) / Laundry Center
Frigidaire LC248W1 Frg(v1) / Laundry Center
Frigidaire LC400RXD1 Wwh(v2) / 24 " Washer
Frigidaire LC400RXD2 Wwh(v2) / 24 " Washer
Frigidaire LC400RXD3 Wwh(v2) / 24 " Washer
Frigidaire LC400RXW1 Wwh(v1) / 24 " Washer
Frigidaire LC400RXW2 Wwh(v1) / 24 " Washer
Frigidaire LC400RXW3 Wwh(v1) / 24 " Washer
Whirlpool LC4500XKW0
Whirlpool LC4500XMW0
Whirlpool LC4500XMW1
Whirlpool LC4500XSW0
Whirlpool LC4500XTF0
Whirlpool LC4500XTG0
Whirlpool LC4500XTG1
Whirlpool LC4500XTM0
Whirlpool LC4500XTN0
Whirlpool LC4500XTN1
Whirlpool LC4500XTW0
Whirlpool LC4500XTW1
Whirlpool LC4600XKW0
Whirlpool LC4900XKW0
Whirlpool LC4900XMW0
Whirlpool LC4900XMW1
Whirlpool LC4900XSW1
Whirlpool LC4900XTF0
Whirlpool LC4900XTG0
Whirlpool LC4900XTM0
Whirlpool LC4900XTN0
Whirlpool LC4900XTW0
Whirlpool LC4900XTW1
Frigidaire LC550EXD3 Wwh(v1) / Top Loading Washer
Frigidaire LC550EXP3 Wwh(v2) / Top Loading Washer
Frigidaire LC550EXW3 Wwh(v3) / Top Loading Washer
Frigidaire LC550LXD0 Wwh(v2) / Washer
Frigidaire LC550LXD1 Wwh(v2) / Washer
Frigidaire LC550LXW0 Wwh(v1) / Washer
Frigidaire LC550LXW1 Wwh(v1) / Washer
Frigidaire LC590EXD2 Wwh(v4) / Top Loading Washer
Frigidaire LC590EXD3 Wwh(v5) / Top Loading Washer
Frigidaire LC590EXW2 Wwh(v6) / Top Loading Washer
Frigidaire LC590EXW3 Wwh(v7) / Top Loading Washer
Frigidaire LC590LXD0 Wwh(v2) / 24 " Top Load Washer
Frigidaire LC590LXD2 Wwh(v2) / 24 " Top Load Washer
Frigidaire LC590LXW0 Wwh(v1) / 24 " Top Load Washer
Frigidaire LC590LXW2 Wwh(v1) / 24 " Top Load Washer
Maytag LCBG500 RANGE- F/S STD GAS
Maytag LCBG501 RANGE- F/S STD GAS
Maytag LCCE700 WALLOVEN- S/C MWAVE ELE
Maytag LCCE701 WALLOVEN- S/C MWAVE ELE
 LCE3081ST Electric Range
 LCE30845 Electric Range
 LCE3681ST Electric Range
Whirlpool LCE4332PQ0 COMPACT AUTOMATIC WASHER
Whirlpool LCE4332PQ1 COMPACT AUTOMATIC WASHER
Frigidaire LCE441AL1 Frg(v2) / 24 " Laundry Center
Frigidaire LCE441AW1 Frg(v1) / 24 " Laundry Center
Frigidaire LCE441LL2 Frg(v1) / 24 " Laundry Center
Frigidaire LCE441LW1 Frg(v1) / 24 " Laundry Center
Frigidaire LCE441LW2 Frg(v2) / 24 " Laundry Center
  #2 (permalink)
Old 04-16-2012, 06:06 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
It is probably the water level switch, this part here.
Part number: AP4568145
I would first clean out the hose running from that switch to the tub, but when that is a problem the usual symptom is that it overflows.
__________________
  #3 (permalink)
Old 04-23-2012, 01:54 PM
Junior Member
Default
Replacement pressure switch fixed it.
Thank you for your help.
KRS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch axxis washer "water tap closed" error jstew0903 Washer Repair 1 07-28-2015 02:15 PM
washer smells / is moldy, "balance asm" full of water beek9029 Washer Repair 0 07-15-2010 07:00 PM
water runs right thru it, never fills up thengy Washer Repair 1 06-08-2010 03:08 PM
water fills then empties then runs cycle dry RussT Dishwasher Repair 2 05-03-2010 05:40 PM
Maytag washer "buzzes" but does not fill with water pkonrath147 Washer Repair 0 06-06-2008 01:21 AM
