Discuss
Maytag washer will not drain during spin cycles and continues to next cycle
 in
Washer Repair
The washer will not drain completely, it leaves almost half of the water after the spin cycles and then when
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer will not drain during spin cycles and continues to next cycle
  #1 (permalink)
Old 09-03-2009, 08:20 AM
Junior Member
Laine is on a distinguished road
Default Maytag washer will not drain during spin cycles and continues to next cycle
Model Number: A512   Brand: Maytag   Age: More than 10 years
The washer will not drain completely, it leaves almost half of the water after the spin cycles and then when it should stop at the end of the cycle, it continued to the next cycle. Is there a way to reset it or can this be fixed inexpensively. Is it time for a new set? Thank you in advance for your help..
Laine
Related Models
Maytag A512 WASHER-TOP LOADING
Maytag A512S WASHER-TOP LOADING
Jenn-Air A516 MISC / ACCESSORY
Jenn-Air A518S MISC / ACCESSORY
Jenn-Air A519 MISC / ACCESSORY
Jenn-Air A519W MISC / ACCESSORY
Jenn-Air A521B MISC / ACCESSORY
Jenn-Air A521W MISC / ACCESSORY
Jenn-Air A526 MISC / ACCESSORY
Jenn-Air A526W MISC / ACCESSORY
Jenn-Air A527B MISC / ACCESSORY
Jenn-Air A530 MISC / ACCESSORY
Jenn-Air A530W MISC / ACCESSORY
Admiral A54F-5TKXW-R WALLOVEN- S/C GAS
Admiral A54F-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FK-5TKXWM-R WALLOVEN- S/C MWAVE GAS
Admiral A54FN-5TKVW-R WALLOVEN- S/C GAS
Admiral A54FN-5TKVWM-R WALLOVEN- S/C MWAVE GAS
Admiral A5651XRS RANGE- D/I CONT CLEAN ELE
Admiral A5892XRS RANGE- S/C D/I ELE
Admiral A5898VRV RANGE- S/C D/I ELE
Admiral A5898XRB RANGE- S/C D/I ELE
Admiral A59-5EXW-R WALLOVEN- S/C ELE
Maytag A590 WASHER-TOP LOADING
Maytag A5910 WASHER-TOP LOADING
Admiral A59E-5EXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXW-R WALLOVEN- S/C ELE
Admiral A59F-5TXWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59FN-5TVW-R WALLOVEN- S/C ELE
Admiral A59FN-5TVWM-R WALLOVEN- S/C MWAVE ELE
Admiral A59G-5TXW-R RANGE- F/S STD ELE
Admiral A59GN-5TVW-R RANGE- F/S STD ELE
Frigidaire A5LECC2 Frg(v3) / Room Air Conditioner
Frigidaire A5LECDC2 Frg(v4) / Room Air Conditioner
Frigidaire A5LECDD2 Frg(v13) / Room Air Conditioner
Frigidaire A5LECDSD2 Frg(v14) / Room Air Conditioner
Frigidaire A5LECUC2 Frg(v12) / Room Air Conditioner
Maytag A606 WASHER-TOP LOADING
Maytag A606S WASHER-TOP LOADING
Maytag A608 WASHER-TOP LOADING
Maytag A608S WASHER-TOP LOADING
Maytag A610 WASHER-TOP LOADING
Maytag A612 WASHER-TOP LOADING
Maytag A612S WASHER-TOP LOADING
Maytag A613 WASHER-TOP LOADING
Admiral A6257XRS RANGE- S/I CONT CLEAN GAS
Jenn-Air A626B MISC / ACCESSORY
Jenn-Air A627W MISC / ACCESSORY
Admiral A6498VRV RANGE- S/C S/I GAS
Admiral A6498XRS RANGE- S/C S/I GAS
Admiral A64HN-4TKVW-R RANGE- S/C S/I GAS
Admiral A6892XRS RANGE- S/C S/I ELE
Admiral A6898VRV RANGE- S/C S/I ELE
Admiral A6898XRB RANGE- S/C S/I ELE
Admiral A68HK-6TXW-R RANGE- S/C S/I ELE
Maytag A6910 WASHER-TOP LOADING
Frigidaire A6LECC2 Frg(v5) / Room Air Conditioner
Frigidaire A6LECC3 Frg(v1) / Room Air Conditioner
Frigidaire A6LECD2 Frg(v15) / Room Air Conditioner
Frigidaire A6LECDC2 Frg(v13) / Room Air Conditioner
Frigidaire A6LECDC3 Frg(v14) / Room Air Conditioner
Frigidaire A6LECDD2 Frg(v16) / Room Air Conditioner
Frigidaire A6LECUD2 Frg(v17) / Room Air Conditioner
Frigidaire A6LECUSD2 Frg(v18) / Room Air Conditioner
Maytag A700 WASHER-TOP LOADING
Maytag A700S WASHER-TOP LOADING
Maytag A702 WASHER-TOP LOADING
Maytag A702S WASHER-TOP LOADING
Maytag A710 WASHER-TOP LOADING
Maytag A710S WASHER-TOP LOADING
Maytag A712 WASHER-TOP LOADING
Maytag A7300 WASHER-TOP LOADING
Maytag A7400 WASHER-TOP LOADING
Maytag A7500 WASHER-TOP LOADING
Maytag A7500S WASHER-TOP LOADING
Maytag A7500W WASHER-TOP LOADING
Maytag A7800 WASHER-TOP LOADING
Admiral A79E-5CXW WALLOVEN- S/C ELE
Admiral A79F-5EXW-R WALLOVEN- S/C ELE
Admiral A79FN-5EVW-R WALLOVEN- S/C ELE
Frigidaire A7LECUD2 Frg(v19) / Room Air Conditioner
Maytag A806 WASHER-TOP LOADING
Maytag A806S WASHER-TOP LOADING
Maytag A810 WASHER-TOP LOADING
Maytag A8100 WASHER-TOP LOADING
Maytag A8120 WASHER-TOP LOADING
Maytag A8140 WASHER-TOP LOADING
Maytag A8200 WASHER-TOP LOADING
Maytag A8210 WASHER-TOP LOADING
Admiral A8210PA SURFACE UNIT- GAS
Admiral A8210PA-L SURFACE UNIT- GAS
Admiral A8210PT-L SURFACE UNIT- GAS
Admiral A8210PW SURFACE UNIT- GAS
Admiral A8210PW-L SURFACE UNIT- GAS
Admiral A8211PA SURFACE UNIT- GAS
Admiral A8211PS SURFACE UNIT- GAS
Admiral A8211PW SURFACE UNIT- GAS
Maytag A8240 WASHER-TOP LOADING
Admiral A8241RA SURFACE UNIT- GAS
Admiral A8241RA-L SURFACE UNIT- GAS
Admiral A8241RS SURFACE UNIT- GAS
Admiral A8241RT-L SURFACE UNIT- GAS
Admiral A8241RV SURFACE UNIT- GAS
Admiral A8241RW SURFACE UNIT- GAS
Admiral A8241RW-L SURFACE UNIT- GAS
Admiral A8261RB SURFACE UNIT- GAS
Admiral A8261RV SURFACE UNIT- GAS
Admiral A82LK-3K-R SURFACE UNIT- GAS
Admiral A82LN-3K-R SURFACE UNIT- GAS
Admiral A82LW-2K-R SURFACE UNIT- GAS
Admiral A8321PA SURFACE UNIT- GAS
Admiral A8321PS SURFACE UNIT- GAS
Admiral A8321PW SURFACE UNIT- GAS
Admiral A8321TA-L SURFACE UNIT- GAS
Admiral A8321TW-L SURFACE UNIT- GAS
Maytag A8340 WASHER-TOP LOADING
Maytag A8420 WASHER-TOP LOADING
Maytag A8440 WASHER-TOP LOADING
Maytag A8500 WASHER-TOP LOADING
Maytag A8520 WASHER-TOP LOADING
  #2 (permalink)
Old 09-03-2009, 08:55 AM
Frank / APP Team's Avatar
Senior Expert
Frank / APP Team is on a distinguished road
Default
Quote:
Laine
I would start with removing the front panel of the washer and see if you see anything stuck in the pump, which is somewhat clear in appearance. From there, there is a hose that goes from the pump up to the tub and those machines were notorious for getting a small article of clothing stuck in them or even a coin that came out of an article of clothing.
Far as a new set, I would hang on to those if I were you, if they're in good shape. They were very good machines. It's when a Maytag was a real Maytag.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #3 (permalink)
Old 09-03-2009, 09:22 AM
Junior Member
Default
Thanks for your response, we bought the set used about 6-7 years ago, so we do not have a manual. We are not sure how to remove the front panel safely. Can you direct us to a website for instruction or can you explain how to do this. We tried to download a manual at the Maytag site , and there was not one available. Once the panel is off how would we remove an object that might be stuck? Do we need to drain the tub full of water first? These have been a reliable set til now, I do hope we can fix them.
Thanks again, Laine
  #4 (permalink)
Old 09-03-2009, 10:01 AM
Junior Member
Default
helllllooooo, is anybody out there? Just waiting for a response please reply, we are on our way out of town and needed a response before we leave. Thanks
  #5 (permalink)
Old 09-03-2009, 10:15 AM
Senior Expert
Default
Yes we're here, along with hundreds of other questions.
Can not provide a manual for you. There are two screws down at the bottom of the front panel a couple of inches up from the floor. You won't see them unless you get on your hands and knees to look. They are in the indented area, angled up. Remove them and the bottom will swing up and out and release from the top. You will see the pump in the right front corner and the hose I spoke of is obvious. When you remove the hose water is going to go everywhere, so you will probably want to bail/scoop/etc., whatever water out you can before removing the hose.
Also make make sure the pump pulley underneath the machine turns freely.
__________________
  #6 (permalink)
Old 05-09-2010, 02:44 PM
Junior Member
bardo99 is on a distinguished road
Default
My washer isn't draining properly. I took apart the front and found a sock lodged in the pump. I put it all back together but it didn't solve the problem. The switch also doesnt stop at "off", but it keeps going through all of the cycles. I'm not sure if these are related or not but the problems began at the same time.
  #7 (permalink)
Old 03-20-2013, 08:28 PM
Junior Member
DarrickP is on a distinguished road
Default Stupid Sock!
Took the front off of the machine, unclamped the hose into the pump (prepared for the flood), reached my finger up inside...A SOCK!! lol Wouldn't have thought it could have made it there, especially that there was still some water going through.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
tub does not drain, continues into next cycle edmalcolm Washer Repair 1 01-05-2010 05:14 PM
washer cycles spin cycle when running DBoelman Refrigerator & Freezer Repair 0 11-15-2009 03:13 PM
Maytag washer wont drain on spin cycle Jacko1002 Washer Repair 2 08-02-2009 08:07 AM
Maytag washer won't drain before spin cycle marklyn Washer Repair 9 03-02-2009 01:05 PM
Spin and pump cycles stop and start, washer won't drain grosshaus Washer Repair 1 03-31-2008 02:10 PM
