Discuss
high torque transmission
 in
Washer Repair
My tub seal was leaking and it took out the triple lip seal bearing. I ordered replacement parts and the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » high torque transmission
  #1 (permalink)
Old 09-02-2009, 10:30 PM
lmoseley7 lmoseley7 is offline
Junior Member
lmoseley7 is on a distinguished road
Default high torque transmission
Model Number: HAV2460AWW   Brand: Maytag   Age: 5 - 10 years
My tub seal was leaking and it took out the triple lip seal bearing. I ordered replacement parts and the new seal/bearing manual mentions that it should only be used with the high torque transmission, which I don't have. The old setup had a metal "nut" and a plastic nut, but the new one has just the metal piece; the plastic nut has been replaced by a redesigned metal nut. Why can't I use the new parts on the old transmission? Will it hurt to do so? The high torque transmission was an upgrade to my model.
Related Models
Maytag HAV2460AWW Washer - Top Loading
Maytag HAV2557AWW Washer - Top Loading
Maytag HAV2558AWW Washer - Top Loading
Maytag HAV3460AWW Washer - Top Loading
Hoover HAV4200AKW Washer - Top Loading
Hoover HAV4200ATW Washer - Top Loading
Hoover HAV4200AWW Washer - Top Loading
Maytag HAV4657AWW Washer - Top Loading
Maytag HAV4657EWW Washer - Top Loading
Magic Chef HB100-30 Hood
Magic Chef HB100-36 Hood
Magic Chef HB100-42 Hood
Magic Chef HB100A-30 Hood
Magic Chef HB100A-36 Hood
Magic Chef HB100A-42 Hood
Magic Chef HB100D-30 Hood
Magic Chef HB100D-36 Hood
Magic Chef HB100D-42 Hood
Magic Chef HB100DA-30 Hood
Magic Chef HB100DA-36 Hood
Magic Chef HB100DA-42 Hood
Thermador HB30QB
Thermador HB30QS
Thermador HB30QW
Thermador HB36QB
Thermador HB36QS
Thermador HB36QW
Bosch HBL432 AUC (FD 8202-)
Bosch HBL435 AUC (FD 8202-)
Bosch HBL436 AUC (FD 8202-)
Bosch HBL442 AUC (FD 8202-)
Bosch HBL445 AUC (FD 8202-)
Bosch HBL446 AUC (FD 8202-)
Bosch HBL452 AUC (FD 8202-)
Bosch HBL455 AUC (FD 8202-)
Bosch HBL456 AUC (FD 8202-)
Bosch HBL532
Bosch HBL535
Bosch HBL536
Bosch HBL542
Bosch HBL545
Bosch HBL546
Bosch HBL552
Bosch HBL555
Bosch HBL556
Bosch HBL562
Bosch HBL565
Bosch HBL566
Bosch HBL632
Bosch HBL635
Bosch HBL636
Bosch HBL642
Bosch HBL645
Bosch HBL646
Bosch HBL652
Bosch HBL655
Bosch HBL656
Bosch HBL662
Bosch HBL665
Bosch HBL666
Bosch HBL742 AUC (FD 8207-)
Bosch HBL745 AUC (FD 8207-)
Bosch HBL746 AUC (FD 8207-)
Bosch HBL752 AUC (FD 8207-)
Bosch HBL755 AUC (FD 8207-)
Bosch HBL756 AUC (FD 8207-)
Bosch HBL765 AUC (FD 8207-)
Bosch HBN442 AUC
Bosch HBN445 AUC
Bosch HBN446 AUC
Bosch HBN452 AUC
Bosch HBN455 AUC
Bosch HBN456 AUC
Bosch HBN642
Bosch HBN645
Bosch HBN646
Bosch HBN652
Bosch HBN655
Bosch HBN656
Bosch HBN662
Bosch HBN665
Bosch HBN666
Bosch HBN742 AUC (FD 8207-)
Bosch HBN745 AUC (FD 8207-)
Bosch HBN746 AUC (FD 8207-)
Bosch HBN752 AUC (FD 8207-)
Bosch HBN755 AUC (FD 8207-)
Bosch HBN756 AUC (FD 8207-)
Bosch HBN765 AUC (FD 8207-)
Magic Chef HC309B-2 Hood
Magic Chef HC30AB-2 Hood
Frigidaire HC30C Frg(v1) / Range Vent Hood
Frigidaire HC30CL Frg(v2) / Range Vent Hood
Frigidaire HC8830S Frigidaire / Range Hood
Frigidaire HC8830W Frigidaire / Range Hood
Frigidaire HC8836S Frigidaire / Range Hood
Frigidaire HC8836W Frigidaire / Range Hood
Hardwick HCF120 Freezer - Vertical
Hardwick HCF170 Freezer - Vertical
Hardwick HCF200 Freezer - Vertical
Hardwick HCF200A Freezer - Vertical
Hardwick HCF200H Freezer - Vertical
General Electric HCK23LCMAFCC Refrigerator
Amana HCL305 Range - S/c S/i Ddraft Gas
Amana HCL605 Range - S/c S/i Ddraft Gas
Amana HCR305 Range - S/c S/i Ddraft Gas
Amana HCR306 Range - S/c S/i Ddraft Gas
Amana HCR3061L Hood
Amana HCR3061L Hood
Amana HCR3061W Hood
  #2 (permalink)
Old 09-03-2009, 01:43 PM
sidfink43 sidfink43 is online now
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
I don't know why this is the case but Maytag is pretty adamant about not using the new design unless there is a high torque transmission. Here is the tech bulletin on the change.
http://www.servicematters.com/maytag...TDL-0086-B.pdf
I have not been able to see the older part for the non high torque transmission. I would go back to the place you purchased the seal kit from and explain what you need and see if they can determine what seal kit will work with your machine. The should exchange the part you purchased for the right part.
Good luck, let us know what happens.
__________________
  #3 (permalink)
Old 09-04-2009, 05:14 PM
Junior Member
Default To use it or not to use it...
I actually purchased the parts from this website. I called the sales people and she discussed it with people that should know and they said the original parts were discontinued. The only difference that I can see is that before there was a metal piece that screwed onto the transmission shaft and then a plastic nut on the outside of that with a rubber seal. Now the metal piece has the rubber seal and it looks like the plastic nut is no longer needed (even though I ordered one). What I can't figure out is how a low torque transmission would tear up something made for a high torque transmission. The only other option I know of is to replace the entire transmission which is cost prohibitive ($250). I'm going to give these parts a try and hopefully it lasts. If not I'll post again.
  #4 (permalink)
Old 09-04-2009, 05:59 PM
Senior Expert
APP Volunteer
Default
Ok, good. I was afraid that the old part was not available. Maytag probably designed this process so that the tech would have to replace the transmission and the new seal assembly, doesn't cost them anything and they make a few bucks on the deal.
Good luck, let us know how it turns out.
__________________
  #5 (permalink)
Old 09-05-2009, 09:44 AM
Junior Member
Default New seal nut doesn't work
So I tried putting everything back together using the new parts and the new seal nut's threads are different than the old threads. Luckily I had also purchased the plastic nut and I was able to use the old metal seal nut. None of this affected the bearing which was the major issue. I unfortunately disassembled the brake mechanism when I was tearing the washing machine down, only to find out that it was an unnecessary step and also seems to be posing some significant issues trying to get it back together because of the spring inside the brake. Anyone have any suggestions?
  #6 (permalink)
Old 09-05-2009, 03:05 PM
Senior Expert
APP Volunteer
Default
Here is the service manual. Be very careful as you are dealing with a spring under very high pressure.
http://www.servicematters.com/maytag...s/16023083.pdf
__________________
  #7 (permalink)
Old 09-16-2009, 05:28 PM
Junior Member
Default Just to wrap it up!
The problem I had with my washer was that the tub was leaking and had damaged the bearing in the tub seal. The washer has an inner and outer tub, of course. The outer tub bolted to a round plastic seal that contained a bearing in the middle. The inner tub was bolted to a metal piece that was mostly square and about 1 1/2" thick and maybe 4" across. That piece was threaded in the center and screwed onto the transmission shaft. The gasket that was originally between the inner tub and the metal seal/nut was improperly positioned and more than likely is what caused the original leak. After the metal seal/nut, originally was a plastic nut with a rubber seal. The new part combined the metal seal/nut and the plastic nut into one piece, however the thread pattern was different and therefore would not screw onto the shaft of the old low-torque transmission. I assume this was the only difference and why they cautioned you not to use it on the old transmission. Luckily I had purchased a new nut as removing the original was difficult and it was damaged in the process. As for reinstalling the brake, I first made sure I sanded all the metal in the brake assembly b/c there was a bit of light rust due to the water leak. I then sprayed with brake parts cleaner. I reassembled the brake assembly by using 2" 10 24 screws. The screws in the machine were 1/2" 10 24. The longer screws allowed me to compress the spring enough so that the shorter screws could be inserted. There are 6 screws in all. I installed 4 long ones and slowly tighted each of them about 1-2 full turns in order until I could install 2 shorter screws. Once the shorter screws were in, I then replaced the longer ones and continued my 1-2 turn process until they were all tight. Reinstalling the drive pully was interesting as the snap ring groove wasn't visable despite the brake assembly being tight. I ended up trying to tighten the brake assembly just a little more and grinding a tiny bit on the last washer before the snap ring in order to get it started. Since then we are about a dozen loads of clothes later and it is working like a champ.
  #8 (permalink)
Old 09-16-2009, 06:10 PM
Senior Expert
APP Volunteer
Default
Nice going, and pretty interesting about the new/old bearing kit.
Thanks for the detailed description, I am sure all of us will benefit from it and thanks for the update.
__________________
  #9 (permalink)
Old 09-16-2009, 06:40 PM
Junior Member
Default
I know that I'm not calling these items by their true names, but hopefully if someone is working on a similar machine, it will make sense.
  #10 (permalink)
Old 09-16-2009, 10:35 PM
johncockrell johncockrell is offline
Junior Member
johncockrell is on a distinguished road
Default Similar problem
I have a Maytag model# MAV5000AWW with the same leaking problem. I have ordered the same part with the same comment about high torque transmissions. I have tried my new type spin hub and the threads on the tranny are the same. I am going to try the assembly with the new parts and see what happens.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Torque specs for transmission/brake assm Newmann744 Washer Repair 0 08-13-2009 06:15 PM
spin slow ,no torque jonandjanc Washer Repair 4 07-10-2009 12:37 PM
Torque mklock3 Trash Compactor Repair 0 07-04-2009 10:27 AM
Making high pitch noise as if trying to start compressor and high temp alarm coming Dbengali Refrigerator & Freezer Repair 2 06-22-2009 10:14 AM
Run Capacitors: does it affect compressor start torque? 80sGuy Refrigerator & Freezer Repair 2 09-10-2008 05:27 AM
