Discuss
high torque transmission
 in
Washer Repair
We have another poster with the same issue; I am just going to reference your posts for him.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » high torque transmission
  #11 (permalink)
Old 09-17-2009, 07:22 AM
sidfink43 sidfink43 is offline
Senior Expert
APP Volunteer
sidfink43 is on a distinguished road
Default
__________________
  #12 (permalink)
Old 09-17-2009, 09:25 AM
magician59 magician59 is offline
Senior Expert
APP Volunteer
magician59 is on a distinguished road
Default
Quote:
Originally Posted by lmoseley7 View Post
So I tried putting everything back together using the new parts and the new seal nut's threads are different than the old threads. Luckily I had also purchased the plastic nut and I was able to use the old metal seal nut. None of this affected the bearing which was the major issue. I unfortunately disassembled the brake mechanism when I was tearing the washing machine down, only to find out that it was an unnecessary step and also seems to be posing some significant issues trying to get it back together because of the spring inside the brake. Anyone have any suggestions?
Find three screws (#8-32) that are a half inch longer than the ones used on the brake stator. Assemble the brake spring and rotor, and start the connection with the long screws. When they start to draw the stator in, add the short ones. The pattern will alternate long, short, long, short... Tighten them equally and when they're snug, tighten the short ones. This will take some time, but it beats purchasing the brake tool--unless you plan to do this for a living.
__________________
Nemo malus felix
  #13 (permalink)
Old 10-27-2009, 08:38 PM
johncockrell johncockrell is offline
Junior Member
johncockrell is on a distinguished road
Default
I have completed the repair on this washer using the parts for the high torque tranny on my old tranny . After a month of use all seems to be working great.
  #14 (permalink)
Old 10-28-2009, 04:08 AM
Senior Expert
APP Volunteer
Default
Great, glad that is working out for you, and thanks for updating us. This information is very helpful, as you can see from the number of views of this thread.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Torque specs for transmission/brake assm Newmann744 Washer Repair 0 08-13-2009 05:15 PM
spin slow ,no torque jonandjanc Washer Repair 4 07-10-2009 11:37 AM
Torque mklock3 Trash Compactor Repair 0 07-04-2009 09:27 AM
Making high pitch noise as if trying to start compressor and high temp alarm coming Dbengali Refrigerator & Freezer Repair 2 06-22-2009 09:14 AM
Run Capacitors: does it affect compressor start torque? 80sGuy Refrigerator & Freezer Repair 2 09-10-2008 04:27 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
